September 08, 2026, 10:32:40 am
Hoffman Amps Forum image Author Topic: Paper over Holes in Speaker Rim  (Read 6090 times)
Offline Khristophorous
  • Born Under A Bad Sign
« on: December 09, 2025, 04:51:15 pm »
What do you guys do with this? It seems like just pushing whatever fastener through this would set it up to tear later. I was thinking about taking a fresh #11 scalpel blade and taking out a neat semi-circle. I read on some other random forum from a search that this is done as a means to show if a speaker is used or not - or has at least been installed somewhere before.
Re: Paper over Holes in Speaker Rim
« Reply #1 on: December 10, 2025, 02:22:30 am »
Don't worry about it, the glue bead (between frame and cone edge) will prevent any tears etc spreading.
Just pushing the bolt through is absolutely fine.
