September 08, 2026, 04:40:32 pm
Hoffman Amps Forum image Author Topic: Fuse size question  (Read 3395 times)
Offline Diverted
Fuse size question
« on: December 11, 2025, 04:15:36 pm »
Hi all,
I'm building a 12W 6V6 push pull circuit, rectifier is a bridge as there is no center tap.
I like to fuse the center tap on the secondaries, but with this one having none, I'm guessing I need to fuse one or both HV AC legs. My question: Approximately what size slow blow fuse should I be looking for? I generally use 500ma to fuse center tap to ground.
Thank you!
Offline astronomicum
Re: Fuse size question
« Reply #1 on: December 11, 2025, 06:28:40 pm »
IMO, one fast blow fuse twice the HT current with the amp at full output.
(Edited)
« Last Edit: December 11, 2025, 06:40:23 pm by astronomicum »
« Reply #2 on: December 11, 2025, 11:48:55 pm »
