September 08, 2026, 04:41:29 pm
Hoffman Amps Forum image Author Topic: Important grounding question  (Read 4108 times)
Offline chaf87
  • Dom Cavati/MG - Brazil
« on: December 22, 2025, 08:43:49 am »
Hello everyone. I'm starting to assemble my second Hoffman 5F6-A. The first one was long time ago. I have a question about the grounding system: in the specific document on grounding, Hoffman instructs us to ground the preamp filter caps to the ground bus and the B+ filter caps to the chassis ground point. However, in the 5F6-A schematic, all the filter caps are grounded to the chassis ground point. Did I miss something? Just to clarify: when I made the Bassman a few years ago, I strictly replicated what was detailed in its schematic. Thank you very much. :m7
« Last Edit: December 22, 2025, 11:56:35 am by chaf87 »
Re: Important grounding question
« Reply #1 on: December 22, 2025, 11:53:57 am »
One or both of the arrangements you show may work fine, perhaps depending on other aspects of the circuit's implementation.
To help understand what's happening, see https://www.valvewizard.co.uk/Grounding.pdf
Given where you are, you'll probably need to read it many times.
Offline chaf87
« Reply #2 on: December 22, 2025, 11:58:38 am »
Ok. Thanks a lot. I'll read this article right now.
« Reply #3 on: December 23, 2025, 05:50:32 am »
If you get stuck with it, don't be afraid to ask  :icon_biggrin:
Offline chaf87
« Reply #4 on: December 23, 2025, 09:02:55 am »
Ok! I think I'll just follow the amp's layout.
« Reply #5 on: December 23, 2025, 11:34:21 am »
... in the 5F6-A schematic, all the filter caps are grounded to the chassis ground point. ...
What schematic are you thinking of, eg https://el34world.com/charts/Schematics/files/Fender/Fender_bassman_5f6a.pdf
A real 5F6a looks to have the decoupling cap for the preamp supply mounted on the circuit board.
Whatever, if you're unsure of the theory, it's a very good idea to follow a proven arrangement.
