September 14, 2026, 06:09:20 pm
Hoffman Amps Forum image Author Topic: Guitar intonation  (Read 12892 times)
Guitar intonation
« on: December 23, 2025, 01:12:14 pm »
I have been trying different intonation methods.
I do not tune open and then do a 12th fret harmonic
When you press down on a string, it goes sharp compared to a harmonic
So if you tune an open E to pitch and press down on the 5th fret, the A is sharp.
Same if you tune with a 12th fret harmonic
A fretted 12th fret is more accurate than a harmonic 12th fret
So Now I am messing around with a fretted 3rd fret and fretted 15th fret.
If you set the intonation up that way, the open string is now flat
But you probably play fretted notes more than open notes, so it's a compromise
And don't get me started on the G string mess
I always tune the G string down a few cents flat and it sounds better to my ear
Anyone have a favorite intonation method
« Last Edit: December 23, 2025, 01:14:31 pm by EL34 »
Offline Rontone
  • Ixnay on the Ampscray
Re: Guitar intonation
« Reply #1 on: December 23, 2025, 03:44:42 pm »
The eternal quest....
I have started doing that more, its not a well known tip really, most videos on youtube will tell you to adjust the saddles according to open and 12th fret to get them dialled in, but now I like checking the "harmonic" areas, 5th, 7th, 15th and 17th and just keep tweaking
The G string tuning thing hasn't bothered me too much in the past, I have B string problems and I wonder now if its because I naturally "sit" into G songs, listening to so much Eagles, Gatton and Buchanan then leading onto other country and rock I started noticing a huge percentage of my favourite songs are just G major, or a modal variant, like Em
Now its winter my guits have tightened up a bit so I need to reset the strat bridge a little, I will try your 3rd / 15th technique
Offline rake
« Reply #2 on: December 23, 2025, 04:00:45 pm »
Doug, the open being flat can be as simple as too much nut height.
The myth that the nut height has to be .020"+ higher than the fret height is BS.
If that were true than a capo on the first fret would make the strings buzz on the second fret?????
Properly levelled frets and no excess nut heights will make a player think you walk on water
and keep coming back for more!
Solid state has no soul........
« Reply #3 on: December 24, 2025, 07:01:56 am »
I am not sure what the nut slot heights should be
What measurement is good above the first fret?
Offline rake
« Reply #4 on: December 24, 2025, 07:47:32 am »
My Gibson 82 335S Deluxe (the one in my avatar) is set at only .002" above the height of the frets.
It's an extremely straight neck with .003 of relief and .005 of fall away from the 15th to the 22nd.
Action at the 12th is .050" low E and .045" high E. Milage varies greatly with neck quality though.
To get a neck really straight requires a re-fret. And, a good bit of work and money.
The downside of a low nut is it has to be replaced more often.
« Reply #5 on: January 16, 2026, 03:23:56 pm »
Objectively, if strings are too low at the nut, they will buzz on the early frets.  If too high, fretting a string @ the 1st fret will cause it to go sharp.  I think any height in between is subjective preference.
Rule of Thumb:  when fretting the 3rd fret, the string should just not touch the first fret, which can be verified by feel.
Dan Erlewine's "How to Make Your Electric Guitar Play Great" has a list of this and other setup criteria of various great guitar players.
I pride myself on setting up my own guitars. But sometimes I have to admit defeat, and seek professional help from a luthier.
Offline rake
« Reply #6 on: January 16, 2026, 04:21:53 pm »
Most "Defeats" are due to neck/fretboard issues. Not basic setup errors.
I had a young customer ask me the other day, "how much relief should there be"?
My answer left him confused. I had told him it all depends on the gauge of strings you're playing".  :w2: :help: :dontknow: :think1:
I let him hang for a couple minutes and finally he asked, "why"?
The thicker the string = the wider the envelope. The wider the envelope = the more required relief.
I remember back in the late 80's - early 90's Everyone wanted to be SRV so , off came the .008's & .009's
replaced with .013 -.015 high "E" sets and no one could understand why the damn thing buzzed!
I gave up and started answering, "because you're not Stevie Ray Vaughn"! Some of the other local techs started using
the same answer! Just a little knowledge is freaking dangerous! LOL!
« Reply #7 on: January 17, 2026, 05:17:57 am »
One thing to keep in mind is how hard you pick the strings
I pick extremely hard and need more clearance than  someone who whisper picks
« Reply #8 on: January 17, 2026, 08:48:59 am »
rake: Most "Defeats" are due to neck/fretboard issues. Not basic setup errors.
Good point!!
Turn your amp up!  :icon_biggrin:
Offline rake
« Reply #9 on: January 17, 2026, 06:34:14 pm »
Some players are just diggers! They have to be kicking the shit out of their guitar!
I played with two different guys like that. Both Berklee grads, both great players!
« Reply #10 on: January 18, 2026, 07:56:28 am »
I am not kicking the shit out of my guitar, I just pluck the strings really hard :icon_biggrin:
I need more clearance above the fret because of the wider string swing
Offline rake
« Reply #11 on: January 18, 2026, 09:35:20 am »
Yeah, I remember hearing somewhere that you're a really hard plucker!  :l2:
« Reply #12 on: January 20, 2026, 08:10:35 pm »
I too tend to be a mother plucker.  But the guitar tone really blooms, and sustain is improved, with a soft touch and the amp turned up.
Takes a bit of patience to watch all the way through, but here's some synchronicity:
