September 08, 2026, 04:39:47 pm
Hoffman Amps Forum image Author Topic: Vox AC30/6 Tremolo Woes c.1960  (Read 3207 times)
Offline misterc57
« on: December 24, 2025, 01:06:06 pm »
Hey Folks.  Beed trying to get the tremolo to function on an old AC30/6.
There are two tubes in play.
Replaced many caps and resistors, swapped tubes.  Installed a red LED in place of the cap/resistor at pin 3 cathode of the oscillator.
The circuit needs to be grounded via the footswitch which is missing so I hardwired a ground to the circuit at the proper 1M resistor.
Worked on this about two months ago and had it working briefly with the LED blinking in unison but eventually it slowed down and stopped.
ECC82 modulator with the following readings
pin 1  75   VDC
pin 2
pin 3  3.4  VDC
pin 6  75   VDC
pin 7
pin 8  3.4  VDC
ECC83 oscillator with the following readings
pin 1  220   VDC
pin 2
pin 3  1.5    VDC
pin 6  198   VDC
pin 7  12.5  VDC
pin 8  21.6  VDC
I am baffled by the ECC83 pin 7 and 8 readings.  They seem to feed from the ECC82 pin 2 which has no voltage so I am not sure where the voltage is coming from
but I see the VDC at R71, and I do not think there should ever be DC on a grid.
R71 to pin 7 (green wire) is 3 components to the right of the trim pot lower center of photo.
Schematic I am using courtesy of Jennings is attached.
Any thoughts and help would be greatly appreciated. Thank you.  Mark
Re: Vox AC30/6 Tremolo Woes c.1960
« Reply #1 on: December 24, 2025, 04:08:57 pm »
V9 pins6,7,8 triode is a cathodyne circuit, it takes the oscillator output and creates identical but opposing polarity signals at its anode and cathode.
Scroll down to 'wurlitzer vibrato' for the circuit's theory of operation https://www.effectrode.com/knowledge-base/history-of-vibrato/
« Last Edit: December 24, 2025, 04:25:57 pm by pdf64 »
Offline misterc57
« Reply #2 on: December 27, 2025, 08:53:14 am »
Interesting and I read through that link.  Thank you
So that part of the circuit seems okay?
Can anyone advise on why the tremolo pulse is not engaging?  Thank you
« Reply #3 on: December 28, 2025, 12:21:18 pm »
Maybe one or more components have gone bad. eg R54-59, C22-27?
Offline misterc57
« Reply #4 on: January 02, 2026, 08:10:51 am »
  Thank you.  I have stepped through the circuit numerous times, many components replaced.
