September 08, 2026, 04:42:50 pm
Hoffman Amps Forum image Author Topic: 1977 Ampeg B15n- pin 4 screen voltage is well over the stated spec  (Read 2588 times)
Offline pbman1953
My amp seems to have lost some power and this is very recent.
It's had its caps replaced and its been fine. Last night it wasn't the same amp.
A friend told me to check the screen voltage which should be 445 but it's well over at 550
What's to check first?
Offline SEL49
Re: 1977 Ampeg B15n- pin 4 screen voltage is well over the stated spec
« Reply #1 on: January 13, 2026, 12:11:47 pm »
Replace 6L6s first.
Measure voltages on both 6L6s pins 3, 4, 5, and 8. What have you?
Is the PT original?
Offline pbman1953
« Reply #2 on: January 13, 2026, 12:27:01 pm »
I've tried a few sets of tubes.
One side is 519 volts and the other is about 509-  using A Bias Rite meter
PT is original
pins-
3-548
4-542
5- -051
