September 08, 2026, 04:40:27 pm
Hoffman Amps Forum image Author Topic: Fender 6G8 hum  (Read 7254 times)
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
Fender 6G8 hum
« on: January 13, 2026, 08:50:18 pm »
Hey guys !!
I built this amp about 12 years ago, and with the help of the good folks around here got the amp working properly!
This is the amp I use for giging!
But now the amp is humming what looks to be 60hz,  I may be wrong thou
PA tubes apparently are working hotter, but it is summer and its very hot
Hum increases as volume goes up either channel
I did pull the PI tube to listen if the hum would stop or stay, it does keep happening w/o PI, although with very low volume
Amp does not have master volume
Here some voltage readings, it did not chance from years back
Bias -43
Node A 405 vdc
          B 404 vdc
          C 380 vdc
          D 242 vdc
          E 294 vdc
          F 275 vdc
Some guidance to fix this hum down would be appreciated, thanks in advance!
« Last Edit: January 15, 2026, 11:38:15 am by uki »
https://soundcloud.com/ukiuki
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #1 on: January 14, 2026, 04:05:29 pm »
Also i did a bulb(100w) test
At power on it did flash full light, then faded down to a dimmed light, then with standby on the light increased.
no input signal
follow pictures of the bulb
thanks
« Last Edit: January 14, 2026, 04:13:52 pm by uki »
Offline AlNewman
Re: Fender 6G8 hum
« Reply #2 on: January 14, 2026, 07:58:02 pm »
Maybe one of you're power tubes is not as balanced as it once was.  If you pull the PI and there's still hum it points towards the power section.
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #3 on: January 15, 2026, 09:56:27 am »
I did found the old notes, it is from 1ohm cathode resistor, to compare with today.
old: 25.8mv, 26.2mv, 24.6mv, 24.8mv
today:  V7 20.8mv, V8 20.5mv, V9 20.9mv, 21.5mv
also I've compared the grid resistors:
old: V7 1607ohms, V8 1632ohms, V9 1636ohms, V10 1569ohms
today: v7 1666ohms, V8 1840ohms, V9 1844ohms, V10 1622ohms
Screen resisitors:
I have no notes from before, those read today:
V7 477ohms, V8 498ohms, V9 568ohms, V10 477ohms
All resistors in the amp are carbon composition.
Any help is appreciated, Thanks
picture from 2015
« Last Edit: January 15, 2026, 11:34:01 am by uki »
Offline bmccowan
  • Better builder than player
Re: Fender 6G8 hum
« Reply #4 on: January 15, 2026, 12:06:23 pm »
I agree with Al, tubes first. Got spares? You must if you gig with it. If swapping tubes does not reveal anything, my next step would be to check all the grounds. Easy after 12 years for something to come loose or build up some corrosion. Clean the pots and all plug/jack connections? Filter caps should last 12 years, but :dontknow: Anyways, that's some easy stuff.
Mac
John Prine
Offline AlNewman
Re: Fender 6G8 hum
« Reply #5 on: January 15, 2026, 06:44:32 pm »
Quite a bit less current now than before.  What are your plate voltages at the power tube plates now?  The grid voltage hasn't changed?
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #6 on: January 17, 2026, 08:30:26 am »
No spare tubes, yet.  Indeed i found some loose stuff, but nothing related to the hum thou, grounds are good
It does read the same as years back
v7-10  408 vdc
Also there is a reading from pin 5 to ground in ohms, its different now
old: v7 294k, v8 294k, v9 283k, v10 283k
now: v7 275k, v8 275k, v9 258k, v10 258k
the power tubes does feel hotter, i may be wrong thou
thanks
« Last Edit: January 17, 2026, 08:55:41 am by uki »
Offline AlNewman
Re: Fender 6G8 hum
« Reply #7 on: January 17, 2026, 03:48:46 pm »
Are you measuring with the light bulb still in circuit?
If so that would reduce voltages from operating conditions.
Otherwise, it seems strange there would be less current but similar voltage at the plate.  Perhaps it's a leaky filter cap.  Also, what's your DC voltage at pin 5 of the power tubes?
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #8 on: January 17, 2026, 04:49:43 pm »
No light bulb while reading voltages
Pin 5 of PA tubes -42 vdc
« Last Edit: January 17, 2026, 11:34:57 pm by uki »
Offline AlNewman
Re: Fender 6G8 hum
« Reply #9 on: January 18, 2026, 02:44:46 pm »
Probably want to check resistances across your filter caps with the amp off and drained.  Try with the stand by switch open, as that will isolate the reservoir caps from the other caps in the chain.
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #10 on: January 20, 2026, 09:37:12 am »
I've disconnected the + side of the reservoir caps from the circuit and measured uF and  resistances
cap 1 - 21.98uF ,  there is ohms and raising, did read it until 4-5m
cap 2 - 21.58uF ,  there is ohms and raising, did read it until 4-5m
DMM can read 200m ohms
there was a moment when cap 1 was reading like 160m ohms and raising(confusing), then after reading again it gave the reading above.
DMM battery is new
also i did this test and result seen to be the good case
Also i did a esr test with scope(hope i did this right) follow on pics
Offline AlNewman
Re: Fender 6G8 hum
« Reply #11 on: January 20, 2026, 12:47:24 pm »
What about the filter caps on the pre amp side?  You shouldn't have to lift one end unless you get low readings, there should be no other paths to ground.
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #12 on: January 21, 2026, 09:06:25 am »
Ok got new readings w/o disconnecting the caps.
6m ohms for the power section
16m ohms for the preamp section
Did play a bit with amp to hear what is going on,
amp start with low noise level, the noise increase as the amp warm up,
did play for about 20 minutes.
« Last Edit: January 21, 2026, 04:12:52 pm by uki »
Offline AlNewman
Re: Fender 6G8 hum
« Reply #13 on: January 21, 2026, 08:28:32 pm »
Maybe the power amp caps are weak?  Maybe it's time to focus again on a tube change.  The fact that one of the screen resistors is off spec is interesting.  You could pull 2 tubes, one on each side of the output transformer, check for noise, and then check  the other 2 tubes the same way, and see if you can isolate where the noise is coming from.
The screen resistor should probably be replaced either way.
Offline uki
    • Uki's Guitar Trip
Re: Fender 6G8 hum
« Reply #14 on: January 25, 2026, 09:49:03 am »
Quote from: AlNewman
The fact that one of the screen resistors is off spec is interesting.....The screen resistor should probably be replaced either way.
On to do list!
..... You could pull 2 tubes, one on each side of the output transformer, check for noise, and then check  the other 2 tubes the same way, and see if you can isolate where the noise is coming from.
I did this, and put together all possible pairs, one tube on each side of the OT.
V7/V8, V7/V9, V7/V10,
V8/V9, V8/10, V9/V10
Played at 3 volume levels(3,6,9) with all pairs, at high volume all did sound clean enough  :w2:
There was a very faint hum what i would say it is the normal noise lvl of the amp, maybe not zero but "normal"
what put me to think, before there was a considerable lvl of hum,
so tracing steps back and repluging the pedal board i did find a big hum...  :BangHead:
I will keep watching on this thou, just to make sure amp is ok.
While testing the tube pairs, and fiddling with the tone controls, i did find a weird behavior:
in the tremolo channel if the volume is at max, and turning the treble to max
it does kinda cut the sound, sound get thin and squeshy after 8 or 9. Anything to be concerned about ?
« Last Edit: January 28, 2026, 09:05:18 pm by uki »
Offline AlNewman
Re: Fender 6G8 hum
« Reply #15 on: January 28, 2026, 07:08:31 pm »
I'm not sure, I'm not familiar with that amp.  Sounds like it could be an oscillation issue.  Try rolling some tubes, see if it makes a difference.  Could also try chopsticking around and see if moving wires or components has an effect on it.  Maybe something like a grid stopper on the trem output tube might help, but if it worked ok before, it should work ok now.
