September 08, 2026, 04:40:59 pm
Hoffman Amps Forum image Author Topic: Ampeg B15, there's still sound when the standby is on  (Read 3445 times)
Offline pbman1953
« on: January 17, 2026, 09:16:23 am »
I noticed that ,even though, it reduces over time, I can still hear the bass when the standby is on. It's distorted but doesn't completely shunt the sound
« Last Edit: January 22, 2026, 03:12:46 pm by pbman1953 »
Re: Ampeg B15, I still the bass when the standby is on
« Reply #1 on: January 22, 2026, 02:58:46 pm »
By chance has a high value resistor been wired across the standby switch, as explained in this link https://www.valvewizard.co.uk/standby.html
Offline pbman1953
« Reply #2 on: January 22, 2026, 03:57:51 pm »
no resisitor
Offline ac427v
Re: Ampeg B15, there's still sound when the standby is on
« Reply #3 on: January 23, 2026, 07:47:08 am »
Looks like this standby switch works by cutting the high voltage center tap connection to ground. I've never seen this and do not understand how this relates to your problem. Maybe another member has better insight???
Offline pbman1953
« Reply #4 on: January 23, 2026, 10:29:54 am »
True, it's the design and it's really not a "problem". I just don't like it, because if the cable's is touched there's noise, compared to  a more traditional standby like Fender and others which is a total disconnect.
