September 08, 2026, 04:40:10 pm
Hoffman Amps Forum image Author Topic: Champ-ish "pocket"-amp  (Read 6638 times)
Offline Banjan73
« on: January 19, 2026, 06:37:12 am »
Hello again.
As promised in my recent thread, I have one more amp to present here.
This time, my goal was to make a tiny thing which I could transport on my motorcycle with as much headroom as possible.
I ended up with a kind of champ-amp.
Again, no tone controls. Only gain and volume. This amp throws out about 2,5-3W. When using the tiny, oval speaker in the cabinett, it doesn`t play much in the bass frequenzies. But with an external cabinett, its much better.
Nice amp in very small venues when playing quietly.
I found out that I have no pictures of the internal right now. Coming up, if requested.
Offline dogburn
  • Meddling Kid (but older)
Re: Champ-ish "pocket"-amp
« Reply #1 on: January 19, 2026, 02:19:48 pm »
Looks like a fun project. I've got a somewhat similar amp - an obscure tiny amp with a sort-of 5f2a circuit, which was made in Japan. It's got solid state rectification, 12AX7 preamp, and a 6AQ5 power tube. Easy to transport and sounds good. I think the circuit was really optimized for the 6" speaker, as hooking it up to a larger speaker sounds a bit disappointing.
Offline mountainhick
« Reply #2 on: January 19, 2026, 02:44:35 pm »
Do you have a schematic for the Single Ended 6AQ5? Thanks
Offline Banjan73
« Reply #3 on: January 19, 2026, 03:15:24 pm »
Niice!
Yes, it looks as somewhat the same type of amp.
Did you build the "box" (dont remember the english word right now) yourself?
« Reply #4 on: January 19, 2026, 05:06:58 pm »
I did one like that a while back - a vibrochamp circuit mounted on my own custom Ally folded sheetmetal plate squeezed in an old Behringer Thunderbird box. Stancor A-8092 SE OT, PT out of an old Jap signal jennie and a Mojo Choke. Makes any geetar sound awesome with a Celestion 15W 8" speaker (also has plug for external speaker cab)
Offline pullshocks
« Reply #5 on: January 19, 2026, 05:19:10 pm »
Great projects!
Tubeswell, I'm curious about the Electrical Safety sticker on the back panel.  Did you have it independently evaluate?
« Reply #6 on: January 19, 2026, 05:25:55 pm »
Great projects!
Yep - here we we are, if you want to use any electrical appliance in a performance situation in someone else's venue, there's a legal requirement to have it tag-tested for the integrity of the safety ground and the adequacy of insulation between the AC power supply source and the mains earth. There are independent contractors who have the calibrated equipment who'll do that for $20 and print out the certification label. (The tag is normally supposed to go on the power cord but this has a jug cord, so I slapped it on the back of the chassis, and nobody has complained yet LoL).
Offline dogburn
« Reply #7 on: January 19, 2026, 06:11:54 pm »
[/quote]
Yes, I've got the schematic that was inside the amp, and I added the values to the best of my ability - it was not easy to see all the caps and resistors because of the way it was made. I've attached that here.
Offline dogburn
« Reply #8 on: January 19, 2026, 06:13:14 pm »
Niice!
No, I didn't build the cabinet - that's what it came in. Pretty cool looking tiny thing.
Offline Banjan73
« Reply #9 on: January 20, 2026, 02:21:55 am »
Very cool! Such a nice amp!
Guess I am not the only one here thinking about making such an amp, hehe. This thing also looks awesome! We should come together and have a tiny-amp.jam session, hehe :-)
Great projects!
I used to work at Nemko in Norway. So I know alot about these tests.
Offline printer2
« Reply #10 on: January 22, 2026, 12:55:15 pm »
Using a 12V laptop brick and 0ne of the 45-390V dc boosters to supply a 12AX7 and 6V6. I did up the heat sink on the module and have it outside the chassis for cooler air. A 6K6 (with 12AX7 in series with it along with a resistor parallel with the 12AX7) or a 12AQ5 would play nicely with the module unmolested. I squeezed everything in as small a cabinet as possible, thinned the wood down, 8" speaker just fitting inside. Have a p-p switch on the treble pot and the tone stack goes in between a Marshal and Fender response. Otherwise just a SE Champ type circuit. Debating on adding a delay board or a Digilog reverb yet.
Mostly play through the Blackface position as it makes the amp sound less boxy in the small cabinet (9.5"x9"x6") but has a speaker out jack in case a larger speaker cabinet is kicking around.
Offline Banjan73
« Reply #11 on: January 22, 2026, 08:58:42 pm »
Printer2:
Thats an interresting project!
Can you tell more about the DC booster? Is that an DC-DC converter? Doesn`t those make a lot of noise for audio?
Do you have the full schematics?
Offline printer2
« Reply #12 on: January 24, 2026, 01:28:59 pm »
Printer2:
Booster is the 45-390V one sold everywhere. I found it to be quiet, I use a 10k and 500 pF cap on the input rather than a 33k. One nice thing is no hum whatsoever. Just a Champ type circuit with 100k/1.5k resistors on each triode and 10uF bypass on them. 470R on the output tube with 22uF. Power supply has a 1k for the screen supply and 10k to the triodes, 10uF caps. Nothing unusual. The only different thing is the tone stack. I doubt I would do the switchable responses for it and just stick to the BF response. It works better for the small cabinet.
The HV module does not like putting out a lot of watts when fed by 12V, it will do 15W with 12V. Above that and the rectifier diode gets hot and blows. This is with free air, in a chassis with the tubes heating it up you would have to derate it. I did use a Russian 6N3C on my breadboard and it managed 300V@55mA but eventually it blew the diode. With a a 6V6 in, 350V, 40mA -16V, 14W out of the module I ran it all night. With a fan on it I had it put out 30W
I soldered some foil to the rectifier and 20W out of it. I did paint it black though.
When the diode heats up the turn off time gets longer and more power is dissipated across the diode blowing it. Managed with a 6V6 in SE, 360V 55 mA. Going up to 16V feeding it gave 390V, 104 mA, 41W although I can not remember what heat sink I had on the Mosfet. Rather than the foil I used copper pennies on the diode.
I do have an over sized heat sink on the mosfet in the amp but it barely gets warm. It was already mounted on the module and I left it there. It is a pain changing the heat sink as you have to unsolder a cap on the board in order to use a screwdriver on the heat sink screw. I will be using the module in a P-P amp but using a 19V laptop supply instead, which should solve the heating problem. I used a 12V6 for the output tube ($8 for NOS!) but on 19V I will be using a step down converter. I tested three normally available and two of them have their switching frequency
Starting with the bottom one in the picture. Should be ok charging batteries as long as you do not want current limiting. 250 mV ripple at 12.6V (all measured at 12.6V) and a speedy 16.7 kHz. But it does have mounting holes. The three trimmer one in the middle runs at 72 kHz. Wonder if my high voltage module running at close to the same frequency will cause any problems? Another concern is its 0.5V ripple. One ray of sunshine, as you reduce the voltage out the ripple reduces somewhat the same amount. These ones use a LM2596 which are knockoffs that should be avoided. The top one fairs a little better. It has 180 mV ripple, best so far. Now the biggie, running at 200 kHz, it uses a XL4015 and the chip may actually match the datasheet specs, the LM2596's do not and are to be avoided.
That is about as far as I got with these modules. Originally I wanted to figure out an inexpensive way for a person to make their first 5F1 without an expensive power transformer and a 12V6. Shame about the heating problem at 12V. A 6K6 as the output tube would be a nifty project and should work with the HV module without any modifications. Would be 4W as compared to 6W output with a 6V6.
 A little involved post, tried condensing what I found developing this project. Will be adding a Digilog reverb to it yet.
Offline Banjan73
« Reply #13 on: January 24, 2026, 04:01:09 pm »
I've have to realy analyze your comment here. But this looks nice!
I've thought about using Dcdc converters to do this, but I've always thought that it makes too much noise.
But this proves otherwise.
Another thing if this can provide the current to a full "grown up" push/pull amp....
Offline Banjan73
« Reply #14 on: January 25, 2026, 09:39:28 am »
Printer2: thanks for this great information. For my next small amp, I will for sure consider this approach for the power section. Great!
However, as it seems now my next amp will probably be an Ampeg SB-12 type-of-thing. My son, which plays the bassguitar, wish that I build an amp for him.
So I guess that a step up converter will probably not be aibel to deliver enough current for such a project?
