September 08, 2026, 10:35:38 am
Hoffman Amps Forum image Author Topic: Headstock Decals  (Read 8050 times)
Headstock Decals
« on: January 27, 2026, 03:11:21 pm »
I saw these on Amazon and I thought I would give them a try
I was not expecting them to be as cool as they ended up being
These are not water slide decals
They are a 3 layer assembly
Layer 1 is a a paper backing
Layer 2 is the actual decal
Layer 3 is a very thin clear top sheet that holds the decal together until you peel it off
First you peel off the decal and top film as a unit from the paper backing
I used some double stick tape and stuck the whole thing down so it was easier to lift the decal and top sheet off the paper backing
I used a new Exacto blade to grab the edges of the top clear sheet and peel it off
You stick the decal and top sheet down to the head stock
You rub the decal down hard so it is firmly attached
Then you peel off the thin clear top sheet
It is a bit thicker than a water slide decal but not as delicate
The decal backing is very sticky and hard to remove from the guitar (Ask me how I know that)
I screwed up the extra one they sent and had to remove it
It was not easy to remove it
I used some sticker remover and a razor blade
I ordered two decals thinking I would probably screw one up but they sent 3
They multi decal discounts
The first one is $7.69 but another one is $2.95
Here is the Amazon link
https://a.co/d/jiTmWKD
I think it looks great on my custom Jazzmaster
Re: Headstock Decals
« Reply #1 on: January 28, 2026, 08:20:14 am »
I also added that triple string tree
I ordered another custom decal for my baritone Jazzmaster
« Last Edit: January 29, 2026, 08:19:57 am by EL34 »
Offline Rontone
  • Ixnay on the Ampscray
« Reply #2 on: January 30, 2026, 05:58:24 pm »
After you were talking about intonation on the other thread, how are you find a triple string tree with the tremolo, is it working good?
I've got a 'Wudtone' bridge on my Strat, it has a thin cigarette paper sized shim of metal under the bridge for a better surface, and milled screw holes to get the return to zero better, but I'm wondering if extra string trees and a bit more nut fiddling will get it even better...
« Reply #3 on: January 31, 2026, 06:00:17 am »
Don't know yet
It does seems like the B and E strings do return to zero better
But I had a weird tree that was supposed to be a roller, but it did not seems to roll
I have always had weird things going on with the G string and so I thought I would try the triple tree and see if that made any difference
I need more seat time to figure out how the triple tree is working out
One thing to keep,ion mind is that my trem bar stuff on the Jazzmaster is very subtle
So there's no dive bombing going on  :icon_biggrin:
« Last Edit: January 31, 2026, 06:06:22 am by EL34 »
Offline pullshocks
« Reply #4 on: February 03, 2026, 10:45:30 am »
Thanks for posting this Doug.  Those look really cool. Do you remember the name of the seller?  When I clicked the link it took me to a generic list of crafting supplies.  I tried to search for "custom decal" and did not see anything that looked like what you got.
« Reply #5 on: February 03, 2026, 11:14:36 am »
That's weird. when I click on the link it goes to the right page
I did another link copy
https://a.co/d/0bcgSxEx
The seller is 4950 studio
Do a amazon search for this
Personalized Vintage 50s Style Guitar and Bass Headstock Decals
Offline pullshocks
« Reply #6 on: February 03, 2026, 12:48:39 pm »
That works.  Thanks.
I wonder if they can make larger sizes for an amp control panel.....
« Reply #7 on: February 03, 2026, 12:58:54 pm »
That would be cool
Maybe contact them on Amazon and see
The seller link is here. you can ask them questions
https://www.amazon.com/sp?ie=UTF8&seller=AHOYT61VXBLME&asin=B0DBHWSNBW&ref_=dp_merchant_link
« Reply #8 on: February 10, 2026, 07:00:36 am »
That works.  Thanks.
Did you find anything out?
« Reply #9 on: February 10, 2026, 02:47:57 pm »
Just got the second set of decals
These are for the Baritone Strat I built
