September 08, 2026, 04:40:32 pm
Hoffman Amps Forum image Author Topic: VHT push/pull volume pot  (Read 2752 times)
Offline dsones
« on: February 05, 2026, 09:24:39 am »
I need to replace the push/pull volume pot on a VHT special 6 ultra.  The original dpdt push/pull pot had a small pcb attached to the six pins of the switch modifying how the switch works.  I broke the pcb so I need to wire the push/pull pot to work like the pot worked with the pcb attached.  Does anyone know exactly what the pcb board does?  I know the pcb connects the two sides of the switch together and does something to ground.  Thanks
Re: VHT push/pull volume pot
« Reply #1 on: February 05, 2026, 10:13:02 am »
At the moment I'm on my smartphone, not PC, so I can't perform a good search
Give a look if you can find someting of useful for you here
https://robrobinette.com/Special6UltraMod.htm
and here
https://images.thomann.de/pics/atg/atgdata/document/manual/vht_special_6_ultra_manual.pdf
EDIT:
On the Robinette Special6 there is a photo of the Vol pot and .... no PCB
For connection look to the image and to the schematic on the link
« Last Edit: February 06, 2026, 12:55:41 pm by kagliostro »
Offline dsones
« Reply #2 on: February 09, 2026, 09:45:44 am »
Yes there is a little board sitting on top of the push/pull volume switch.  The board slides over the pins.  The board alters how the switch works.  I've attached a photo.
