September 08, 2026, 04:39:51 pm
Hoffman Amps Forum image Author Topic: Blocking Distortion Example  (Read 4044 times)
Offline apeontheweb
« on: February 05, 2026, 11:42:04 am »
I've been reading about 'blocking distortion' but I can't find any actual examples of recordings. I created this recording: https://youtu.be/j5MlHjA1I5A?si=_s33URtjAMDBb2kq
I ran a Origin Effects Deluxe 55 into a 5E3 (kit). I think when the guitar drops out (you can hear in the video at timestamps 0:08, 0:15, 0:22 etc) that is an example of blocking distortion? I kind of like of it to be honest. I mean I think it has a place in my guitar sounds toolbox. How can I get this effect without running a pedal into the front of the amp?
« Last Edit: February 05, 2026, 11:44:07 am by apeontheweb »
Offline AlNewman
Re: Blocking Distortion Example
« Reply #1 on: February 05, 2026, 10:59:28 pm »
Is it blocking distortion, or are you just pushing your tubes into cut off?
Offline dogburn
  • Meddling Kid (but older)
« Reply #2 on: February 05, 2026, 11:28:50 pm »
What you produced sounds more like a spluttering fuzz pedal, the type of sound you get when the battery is dying, and which is replicated in some newer fuzz pedals. From what I gather, blocking distortion is less appealing.
But you are right in that it is hard to find good sound clips out there to know what it's like. But I don't think you've managed that here. As I understand it, it's more inherent in an amp's circuitry rather than something you can provoke by sending in an overdriven signal.
« Reply #3 on: February 06, 2026, 06:53:24 am »
That sounds like it’s getting pretty blocky to me.
It's not full on blocking, where the signal completely disappears, due to anode current being pushed into cut off by the bias shift being so extreme.
60s style fuzz circuits can get that same effect, especially if there’s a user adjtable bias control.
« Reply #4 on: February 07, 2026, 08:43:28 pm »
yes, blocking distortion
Offline apeontheweb
« Reply #5 on: February 10, 2026, 01:02:12 pm »
Cool thank you for the replies.
Offline apeontheweb
« Reply #6 on: February 10, 2026, 10:54:03 pm »
Is "blocking distortion" the same as "farting out"? If not what is farting out?
« Reply #7 on: February 21, 2026, 05:05:34 am »
My guess is that generally, those terms are used to refer to the same thing, though blocking distortion is the extreme form, in which the signal completely cuts out momentarily.
« Last Edit: February 21, 2026, 05:07:52 am by pdf64 »
