July 25, 2026, 09:05:14 am
Hoffman Amps Forum image Author Topic: Options on reparing/ replacing integral baffle?  (Read 13858 times)
Offline vintasonic
« on: February 09, 2026, 02:18:07 pm »
Not even sure that's the correct term.
I have a Peavey Mace Combo on the bench, the speaker baffle is plywood and has been water damaged, the layers of the plywood are separating.  Despite this, the baffle seems fairly solid, the speaker are mounted securely, most of the damage is at the top of the baffle.
This is not a screw mounted baffle, it is mounted in routed channels in the sides and bottom of the cab - so is integral the proper term?
It seems - outside of trying to re-glue the layers - that the only way to repair is by dis-assembling the cab and replacing the baffle with a new one.  I am not a woodworker and although I have been very successful in repairing many, many damaged cabinets, this, is not really in my wheelhouse and I am at a loss on where to start.
Interestingly, this is one of two Maces I am repairing.  The other has a screwed in baffle made of MDF, both seem factory original
Any suggestions, info, your experiences welcome
Offline dogburn
  • Meddling Kid (but older)
Re: Options on reparing/ replacing integral baffle?
« Reply #1 on: February 09, 2026, 03:16:17 pm »
Could you provide some photos? It's easier for me to visualize solutions that way. It would be a major project to disassemble the whole cabinet to replace a baffle like that.
Offline vintasonic
« Reply #2 on: February 09, 2026, 04:28:30 pm »
I'll post a few pics in the next couple of days.  The amp/ cab is off the bench for the moment while tend to other repairs
Offline Rontone
  • Ixnay on the Ampscray
« Reply #3 on: February 09, 2026, 05:33:04 pm »
I've had a Peavey Mace and a Classic, they were screw in types, I remember thinking about changing the 2x12 to a 1x15 but then got rid of them but that sounds difficult if it is fitted into a channel around the edge
Would it be easy to cut the entire baffle out? is there room to get a jigsaw from the front without damaging the sides too much, then redo it with strips around the edge for a screw in baffle
Offline dogburn
« Reply #4 on: February 09, 2026, 06:21:53 pm »
That's pretty much what I'd do. If the baffle is fitted into channels on three sides, you'd need to cut it so you could remove it without taking apart the whole cabinet. Then put strips of 3/4" wide wood along the bottom and sides to screw in a new baffle or space some cleats along those sides to serve as places for attachment. Also might want to fill in the bottom channel with another strip of wood so the new baffle sits flush on the bottom rather than going down in the channel (you could also just put a few small blocks spaced in the channel rather than filling the whole thing.
Offline rake
« Reply #5 on: February 09, 2026, 07:47:25 pm »
One of them oscillating multi tools may give you a cleaner cut over a jigsaw.
Offline bmccowan
  • Better builder than player
« Reply #6 on: February 10, 2026, 08:31:09 am »
I would not give up on this idea. If you use a glue like Titebond it would need to be clamped. If you use an epoxy it will not need to be tightly clamped.
I would think you'd be able to get some clamps in there - a clamping cleat covered with something the glue won't stick to would allow spreading the pressure.
Of course, I might change my mind after seeing the photos.
Mac
John Prine
Offline vintasonic
« Reply #7 on: March 09, 2026, 07:42:38 pm »
Apologize for not responding sooner, hella busy
So my plan is still along the lines of repair as opposed to replacement, the baffle is separating at the top but is still kinda solid and the speakers help hold it together as well. I will use either Gorilla Wood Glue or Original Gorilla Glue; I have had a lot of luck lately repairing with the Original, it's polyurethane based and fills gaps nicely but the Wood glue might flow between the layers better.
I could but it's more work than I want to put into it at this time.  I could also possibly cut away most of it and leave about an inch of the existing baffle in place to attach a new one. But that also means getting or creating a new baffle  -  the owner is OK with repair if I can make it work
So I think I will start with gluing and clamping and see how it goes.  I have done a bunch of cabinet repair lately, it seems feasible and a lot less work.  This amp is road worn and not going anywhere soon, so repair may be good enough.  Glad to hear your opinions before I start & I'll post after it's done.
« Last Edit: March 09, 2026, 07:44:45 pm by vintasonic »
Offline vintasonic
« Reply #8 on: March 09, 2026, 07:44:08 pm »
another pic
Offline bmccowan
« Reply #9 on: March 10, 2026, 09:59:01 am »
That's not bad at all. Do you have a glue syringe? That would help. Even pressure with the clamps and Titebond should work fine. I think Gorilla Wood Glue is similar to Titebond. I would agree with you as to not using the Polyurethane glue. Let us know how it comes out!
Mac
John Prine
Offline vintasonic
« Reply #10 on: March 10, 2026, 05:34:00 pm »
So in looking around the internet and trying to find a real site about Gorilla vs Titebond, it seems they are about the same, the Titebond may have a little more holding strength with heavy loads.
This site seemed to be real info so either should work https://ralphsway.com/gorilla-wood-glue-vs-titebond/
I don't have a glue syringe but I do have some small plastic bottles with metal syringe tips, about 1/2 long.  I may thin the glue a little to help it run down in the layers, then clamp it in a few places.
Thanks for the input, if it fails then I will have to put in a new baffle but I am pretty confident this should work.
Offline rake
« Reply #11 on: May 21, 2026, 02:55:09 pm »
Not that I'm an expert or anything ( only been using wood glues for 50 years) but here's been my experience.
Water based glues like PVA's (Titebond, Elmer's, etc.) and protein based glues like hide glue, fish glue, old brown glue, etc.
Have excellent holding properties and clean up easily with water.
Urethane glues like Gorilla hold well providing the surfaces have enough "tooth" for the glue to hang on to. smooth surfaces? Not so much.
Cleanup? Not fun.
Cyanoacrylates (superglue) Fast secure hold but it's very brittle and can fail under stress.
Epoxy  Strong bond with most surfaces. Cleanup is a B1tch and it's dang near as messy as working with concentrated stains!
Most all glues have a bond strength that's higher then the lignin holding the "wood" together except for construction adhesive!
Personally I'd go with the water based glues or, wear gloves so you don't stick your hands to the project.  :l3: :pain10: :violent1:
Offline acheld
« Reply #12 on: May 21, 2026, 09:38:03 pm »
Rafe and BMCowan have got it right.
Don't focus on the brand of glue.  Gorilla makes a number of different glues, many of them polyurethane based, but not all.   Do use one of the water based glues.
If it were me, I'd probably use Titebond III "Ultimate" because it has a long assembly time, and it is waterproof (but remember that the wood it glues is NOT!).   A glue syringe would work, but you could just push glue into the voids with a very thin wafer of some sort.  Then clamp.   Only do as much at a time that you can clamp comfortably.  Clean up with a damp rag right after you put the clamps on.
This repair should work great.  Lots easier than cutting a new baffle.
