September 08, 2026, 05:43:57 pm
Hoffman Amps Forum image Author Topic: Sunn 2000s- past updates to understand  (Read 6597 times)
Offline pbman1953
« on: February 16, 2026, 09:03:00 am »
I have a 2000s that was worked on before I got it. There are few items  I have questions on they did and why-
Off pin 8 they used a cap  of 10uf/160v instead of the 250uf along with the 1.5 k resistor across.
The yellow 16 Ohm OT wire wasn't used but was attached to a terminal with a 670 ohm resistor to ground. If a speaker output wire isn't used ,must it be connected? In some of my other amps with a 3rd connection ,when the 4 & 8 ohm were  used, the un-used wire was shrunk tubed
Offline SEL49
Re: Sunn 2000s- past updates to understand
« Reply #1 on: February 16, 2026, 09:54:58 am »
1. Sunn used a 250µF cathode bypass on the input triode to reduce hum due to heater/cathode leakage. I suggest you replace that 10µF.
2. Sunn used the 16Ω tap for NFB. You should also see a 1K and 750pF connected to the 16Ω tap. I suggest you let it be.
Both of the above ideas were used in all of the Sunn amps of that era. They are part of the sound of a Sunn.
Offline pbman1953
« Reply #2 on: February 16, 2026, 10:06:44 am »
The closest I have is a 220 @ 35v, is the voltage important? Because I've seen other preamp schematics with the same position but with a lower voltage item.
Offline SEL49
« Reply #3 on: February 16, 2026, 10:17:41 am »
That's fine.
Offline pbman1953
« Reply #4 on: February 16, 2026, 10:33:34 am »
Offline pbman1953
« Reply #5 on: February 16, 2026, 12:00:54 pm »
Another issue-
one of the 47 ohm, pin 3, resistors is bad,
is 100 ohm overkill
I checked others ,
Traynor & Fender don't have resistors on pin3
Ampeg uses a 5.1
Thoughts?
Offline SEL49
« Reply #6 on: February 16, 2026, 12:26:37 pm »
Use 47Ω only.
Offline pbman1953
« Reply #7 on: February 16, 2026, 03:07:10 pm »
Ok, thanks, I'll look for some
Offline SoundmasterG
« Reply #8 on: February 20, 2026, 05:37:45 pm »
You'll want to use the same type of resistor that Sunn used in that spot. I can't remember if it was wirewound or not, and am not in a place where I could look right now, but use the same type and wattage rating so that it will perform the same as the other ones that are not bad.
Greg
Offline pbman1953
« Reply #9 on: February 20, 2026, 05:58:22 pm »
HI Greg!
I'm not sure if it was you who told me , but  it could be, to change all the 47 ohm grid resistors to 5w white stone resistors. One 47ohm/ 5 watt is the one that became bad. The schematic calls for 2 w
I ordered another one to match
Plus, from the direction of a master tech he told me to add a separate filament transformer so I could use KT-120's. There's plenty of room for it. I can say that there isn't a 2000s that sounds like mine. It's amazing and both transformers don't get very hot
Rich
Offline SEL49
« Reply #10 on: February 20, 2026, 06:22:31 pm »
The 47Ω connected to pin 3 is a plate resistor, not a grid resistor. There should be a total of eight 47Ω/2W resistors, four for plates and four for screens. IIRC, they are all carbon comp.
Offline pbman1953
« Reply #11 on: February 20, 2026, 06:37:24 pm »
Years ago all the carbons, 2W & 5 W were replaced with 42 ohm/5w stone resistors.
Are you saying for the 2w's, pin 4's,  to go back to carbon?
Offline SEL49
« Reply #12 on: February 20, 2026, 07:37:46 pm »
Don't put words in my mouth. This is what I said...
At the time that amp was made, 2 watt CC resistors were very common. But if Sunn was building that amp today, I'm pretty sure they would choose a different resistor and higher wattage and flame proof.
« Reply #13 on: February 21, 2026, 12:48:28 am »
Keep the wirewound ones that you put in there. 5W is better than 2W and wirewound are way better than carbon comp too. Carbon comp can burst into flames when overloaded, and they fail more than WW do. The question is, why did that resistor fail? Do you have a tube that is going south?
Greg
Offline pbman1953
« Reply #14 on: February 21, 2026, 06:48:38 am »
Greg
No worries, they're staying. Once I get the new resistor installed , I can check the tube in that location
Offline pbman1953
« Reply #15 on: February 23, 2026, 08:22:41 am »
Another question, for the bass boost , does the resistor in the circuit control the amount of boost? I'd like it to be less. It's on the boomy side
Online sluckey
« Reply #16 on: February 23, 2026, 09:28:10 am »
No. Replace the .0075 cap with a smaller cap for less boost.
Offline pbman1953
« Reply #17 on: February 23, 2026, 09:42:24 am »
Thanks for writing in, good to see you again!
What value would you start with?
Online sluckey
« Reply #18 on: February 23, 2026, 09:49:36 am »
.001. Let your ears be your guide.
Offline pbman1953
« Reply #19 on: February 23, 2026, 02:10:21 pm »
.002 does the job!
Offline pbman1953
« Reply #20 on: February 25, 2026, 07:26:31 am »
Sorry to bother you all with more but after using the amp a weird issue has come up
Over all the amp is fine and sounds like it should.  While playing I noticed a buzz. I went what to the tone controls to readjust. While turning the Treble control, and playing, there was a spot on the pot that created the buzz. Either side of the spot was clean. Then I figured replace the pot and I installed a new 250k Linear and it was still there.
The Volume, Bass & Contour controls do not exhibit any issues.
What should I look for?
