September 08, 2026, 04:41:04 pm
Hoffman Amps Forum image Author Topic: LED B+ indication  (Read 4537 times)
Offline hylaphone
LED B+ indication
« on: March 02, 2026, 01:55:23 pm »
Hi folks, I've been asked to add an LED to indicate B+ on/off in a tube power amplifier. The B+ is 480V, C/R/C/R/C and each C is two series caps with 220K balancing resistors.Would it be best practice to simply light the LED from the last C node through a honkin resistor?Or - say the last C node is 400V, could I tap from the midpoint (200V) of the series caps so the LED resistor isn't dropping so much voltage? And if so, would I need to adjust the top 220K balancing resistor so currents are equal between the two caps?If this is confusing I'll try and post a schematic....Thanks
Offline acheld
Re: LED B+ indication
« Reply #1 on: March 02, 2026, 02:11:24 pm »
I guess I would ask:  What is the purpose of specifically indicating B+ voltage vs presence of voltage in the heater circuit, or a neon bulb off of the primary input??   Ie, we normally use indicators to tell if the amp is powered on or off.
I guess it could be done safely enough, BUT you're going to dissipate a lot of power through the series resistor.   @400VDC it would be around 7 W, and at 200VDC it would be about 4W.   (There's your honking resistor. . .)
You would be borrowing 10-20 mA from the B+; that is is enough to lower the B+ voltage a bit in the distal legs.   That's probably not much of an issue.
Unless there is a specific good reason for this modification, I feel it is ill-advised.
Offline astronomicum
« Reply #2 on: March 02, 2026, 02:32:56 pm »
They make a handy calculator for this. This page has the numbers plugged in for 200VDC.
https://ledcalculator.net/#p=200&v=1.8&c=1&n=1&o=s
Offline BrianS
« Reply #3 on: March 02, 2026, 02:34:09 pm »
It's okay to say no to a customer once in a while...
« Reply #4 on: March 02, 2026, 02:45:27 pm »
FYI, you only need a 1mA-2mA to light an LED for use as an indicator. No need [for] 10-20 unless you need to see it half way down the block  :icon_biggrin:
[edited]
« Last Edit: March 02, 2026, 03:10:20 pm by astronomicum »
Offline AlNewman
« Reply #5 on: March 02, 2026, 07:52:52 pm »
You can buy a low current led, which is happy at >1mA.  I wouldn't try to put it in series the chain of the mixing resistors on series caps, because that would probably defeat the purpose.  I also wouldn't put it at the end of the chain at the preamp, because it could create noise.  Possibly between the screens and PI, after the dropping resistor with a connection to ground.  Set your resistor at about 2 mA, and you may have to adjust the dropping resistor slightly before the led node to maintain the same voltages.
Offline Merlin
« Reply #6 on: March 03, 2026, 03:32:39 am »
Put the LED in series with one of the balancing resistors, nothing else required.
Offline hylaphone
« Reply #7 on: March 03, 2026, 07:10:10 am »
Thats clever, thank you! And likewise to all the other responses.
« Reply #8 on: March 03, 2026, 07:40:50 am »
Or you can buy a ‘type 47’ 6.3Vac LED and stick it in any old 6v bayonet lamp holder. No extra resistors required.
https://ebay.us/m/SU3S8m
