September 08, 2026, 04:41:53 pm
Hoffman Amps Forum image Author Topic: 5879 amp favorites?  (Read 8091 times)
Offline mountainhick
5879 amp favorites?
« on: March 11, 2026, 10:12:12 am »
There's been many builds here using 5879s. I've been perusing quite a few schematics with jschem.
I just got my hands on a conn strobotuner that I'll repurpose as guitar amp. It's tube compliment is really good, 6x4, a pair of 6AQ5, a 12AU7, a 12AT7 and a 5879. I am happy to use a 6N2P anywhere a 12AX7 would be better.
So wondering about 5879 input stage, perhaps another gain stage, 12AT7 PI etc.
I've built one dual channel amp with one channel a 5879 input into paraphase Gibson GA-40 style, though different power amp. Quite like it. Would like to do something different.
So the range of 5879 designs? I am open to other suggestions. What are your favorites using this tube and why?
Not in any way focused on this, but one idea, wondering about 5879 instead of EF86 for matchless/vox kind of thing.
« Last Edit: March 11, 2026, 10:16:57 am by mountainhick »
Offline passaloutre
Re: 5879 amp favorites?
« Reply #1 on: March 11, 2026, 02:42:28 pm »
I recently did an all "American tube" version of the AC15/Spitfire using an old BH Filmosound amp with 5879,12AX7,6V6,5Y3. I have some noise issues to work out in the tiny chassis, but overall it's a nice round, less-compressed tone than the "English tube" Spitfire I made prior.
« Reply #2 on: March 11, 2026, 02:43:08 pm »
This one is worth doing
5879 Blues Bassman
« Reply #3 on: March 11, 2026, 03:07:25 pm »
Gibson Les Paul GA 40
https://el34world.com/charts/Schematics/files/Gibson/Gibson_les_paul_ga_40.pdf
Sorry, I missed you want to change from the GA 40
« Last Edit: March 11, 2026, 04:03:20 pm by kagliostro »
« Reply #4 on: March 11, 2026, 03:32:35 pm »
5879 Blues Bassman
I have found another version in the Jschem forum, looks potentially desirable, and easy enough to adapt to 6AQ5s.
TIMBO, what's your take on a 12AT7 as PI in that design? Have my own thoughts, but would like to hear others' take on it.
« Reply #5 on: March 11, 2026, 03:34:24 pm »
Sorry, I miss ed you want to change from the GA 40
No worries, Yep been there, done that, and will again, but with 6SJ7s.
Offline SoundmasterG
« Reply #6 on: March 11, 2026, 11:09:58 pm »
Use the 5879 as the second stage instead of the first stage. You get more of the good pentode effects without all the microphonic instability that pentodes often give. Merlin has a lot about it in his books and he's right.
Greg
« Reply #7 on: March 12, 2026, 08:05:45 am »
Greg
Any examples/schematics that use no more than three 9 pin tubes for preamp and PI?
Offline passaloutre
« Reply #8 on: March 12, 2026, 10:43:47 am »
Greg
This one is my new favorite: https://el34world.com/charts/Schematics/files/Kay/Kay720.pdf
That first 5879 doesn't grind very much, but it blasts the pentode that comes after it in the 7199. If you don't want to spend 7199 money, try a 6AN8 or 6GH8. In my build (https://el34world.com/Forum/index.php?topic=33360.0) I even replaced the 5879 with a MOSFET. Sounds great.
If you need to fill a third 9pin socket, you could use it for trem or one-tube reverb.
« Last Edit: March 12, 2026, 10:46:08 am by passaloutre »
« Reply #9 on: March 12, 2026, 02:19:03 pm »
Over the years, I've built all these using a 5879.  Currently, I still own two of them.   The HoSo56 with FX and the Tweed BluezMeister Lite.
I've been very happy with all of them.
Offline bmccowan
  • Better builder than player
« Reply #10 on: March 12, 2026, 02:44:03 pm »
I like that tube, and have built a few:
Matchless Clubman with 5879 instead of the ef86 and a 6V6 power amp. This amp is much tighter than a GA-40.
Modified Dr. Z Z-28 circuit. I married the Z-28 power amp, PI, and tone stack with a Clubman style preamp. No divorce yet.
Tubenit's Minimalist HoSo 56.
GA-40 preamp with a Valco 6973 power amp.
Mac
John Prine
« Reply #11 on: March 12, 2026, 03:22:08 pm »
Coincidentally, I just stumbled onto the Clubman as well. It looks and sounds like a good one for me. Do you still know what kind of voltages you were running with that circuit? And, did you use a parallel power supply scheme?
I am also looking at the Vox AC10 as a good starting point.
« Reply #12 on: March 12, 2026, 03:27:33 pm »
Simple version of Hoso sans reverb looks pretty much like same architecture as the Timbo 5879 bassman? Couple different tweaks. What's your take on your configuration in terms of sound/response?
The OD lite looks like a contender.
Dmars has too many tubes.
I'll pass on the mosfet.
« Last Edit: March 12, 2026, 03:38:28 pm by mountainhick »
« Reply #13 on: March 12, 2026, 08:33:46 pm »
I think the HoSo56 has sort of a fat touch sensitive chimey tone with the right speaker.  My Minimalist HoSo56 using 6BM8 tubes is my #1 gigging amp. And it's a great home recording amp.
Before you throw out the mosfet idea, I suggest you read this:  geofex.com/Article_Folders/mosfet_folly/mosfetfolly.htm
If it's a concern about how to do the mosfet in a layout, I can help with that. If it's a tone thing ........... I don't see it an issue.
The advantage of the mosfet is then I can move a tube triode for a psuedo kinda active FX loop recovery stage. This has worked well for me with reverb, delay, chorus or phase pedals.  I can NOT tell any difference at all between a mosfet cathode follower and a tube triode cathode follower tone wise.
I am not saying you "should build" any of these. Simply throwing out considerations I've been happy with.
« Reply #14 on: March 12, 2026, 09:19:35 pm »
Greg
I can't think of any commercial examples that use the pentode as the second stage. I'm sure there are some out there but not a lot probably. Back in the day they would often just use a pentode at the input like Vox did, but nowadays we know better. A lot of people have built their own things like Tubenit did. I did a parallel 12AX7 into a tone stack, volume control, and 5879, then into a LTP phase inverter on one amp. The power tubes are 7868's so they don't need a bunch of gain in front of them, and it sounds and most importantly feels great. It won't do a really nice clean, but it gains up like an AC30, but is a thicker sound and is maybe even more touch sensitive. It quickly became my #1 amp after I made in in 2012, and it's still going strong. I own an AC30 too. I might make another one with a separate clean channel, but there are so many other circuits I want to build so we'll see.
Greg
« Last Edit: March 21, 2026, 01:19:26 am by SoundmasterG »
Offline bmccowan
« Reply #15 on: March 13, 2026, 07:51:57 am »
The Clubman is a commercial amp with a pentode as a second stage. As you said, there are not many. I don't think we "know better" than to use pentodes for stage one. I think commercial amp companies recognize that pentodes are less common: 5879s are not in production and neither are the octal 6SJ7, 6SH7. EF86s are produced but only one source (I think.) Commercial builders are understandably hesitant to deal with rare tubes. Hobbyists (that's the "we" I assume) are not so restricted and many build both Vox, Gibson, and other style circuits with pentodes in V1 in search of tones outside the 12A_7 universe. They are not better, they are just different.
Yes on the parallel power supply, but I do not consider that a key to the Matchless sound. Since my two Clubmen (one all octal, one with noval preamp) are 6v6 amps I stayed in the 350V+/- range on the power tubes - I know 6v6s will take a lot more, but I like the way they sound in that range.
« Last Edit: March 13, 2026, 08:27:21 am by bmccowan »
Mac
John Prine
« Reply #16 on: March 21, 2026, 01:23:29 am »
What I meant by the nowadays we know better comment was basically if you use a pentode as the first stage and you are trying to get max possible gain out of it like a lot of circuits that used it that way did, it does sound very different from a triode of course, but it is also very susceptible to microphonics when used that way. If you use it as a second stage, you can get a lot of the pentode goodness without having to get maximum gain out of that stage, and that makes it much less susceptible to microphonics.
Greg
« Reply #17 on: March 21, 2026, 09:55:46 am »
Thanks.
This 5879 possibility goes in hand with 6AQ5s. I personally prefer not running them higher than at the recommended 250 plate to cathode volt max in the specs, so the parallel arrangement may help to keep preamp voltage higher compared to power tube voltage. I've done this before for 6AK6.
So pondering what voltage to run the 5879 as second stage...
The parallel voltage supply seems an interesting choice for the Matchless Clubman design. I am curious why they did it.
Offline Carlsoti
« Reply #18 on: March 22, 2026, 01:50:01 pm »
I recently reconfigured a widowmaker Filmosound amp into something similar to the 6V6 powered Clubman bmccowan built and posted docs of. It was a passion project I took on for a guy I work with. It's the only time I've used a 5879, and I like the sound of that amp so much that I'm considering building another one with some more/different features and much improved layout/chassis.
Offline bmccowan
« Reply #19 on: March 22, 2026, 06:22:17 pm »
I think around 150v is good on the 5879 plate - experiment!
I have never seen a great answer as to why Matchless used that parallel power rail. Some say its to better isolate each node  :dontknow: but it does work well. Member dwinstonwood had an interesting discussion on that here. You could probably search it out, or maybe he will chime in.
Mac
John Prine
« Reply #20 on: March 23, 2026, 02:04:25 am »
Something I spun up a few years ago (attached) - Pair of 5879 in tandem, driving a pair of EL34 in parallel SE. All pentodes!  :icon_biggrin:  Split power rails offer better isolation, use higher value filters to compensate for similar ripple reduction as in RC filter networks in series. I used split power rails in this example for the aforementioned reason - Isolation. I think there is a thread on this amp buried in here. OT is a custom part, however, it seems that Edcor now offers something similar to it in their catalog - Link here.
--Pete
