August 29, 2026, 07:20:27 am
Hoffman Amps Forum image Author Topic: Standel 25L15-Do you like it as is or would you like to change something  (Read 78622 times)
Re: Standel 25L15-Do you like it as is or would you like to change something
« Reply #150 on: August 18, 2026, 05:54:17 am »
HBP-Thanks.  I guess I read the schematic incorrectly, or there is a nuance in schematics that I’m ignorant about.
Back in this post you included a schematic from some source.
If you inspect it the connections are:
   - Input Jack Tip connection
   - Coupling cap
   - Resistor to Ground
   - Tube Grid
That pattern is consistent for both channels, and it reflects how we guided you to arrange these parts in the most recent discussion.
Offline wsscott
« Reply #151 on: August 18, 2026, 07:53:28 am »
HBP-The point I was trying to make is that the schematic that I got, and presumably the one you also got, with the NDA is drawn "incorrectly".  Take a look at your's and you'll see what I mean-unless you got something different.
Since the amp seems to be working great now, I think this topic can be closed.  Thanks for everyone's input.
« Reply #152 on: August 18, 2026, 11:24:43 am »
since you're now working from a "different" schematic, does that nullify the NDA??   :icon_biggrin:
