September 08, 2026, 04:41:21 pm
Hoffman Amps Forum image Author Topic: IEC inlet spacer plate  (Read 4568 times)
Offline Blooze
« on: March 13, 2026, 12:50:09 pm »
On the Gibson clone I built I used a JTM45 aluminum chassis that was pre punched for the IEC power entry. The hole is punched at 27.5 x 23mm, so slightly too big. I went with it at the time and had a little trouble getting the little raised clips to be tall enough to catch, but I’m thinking I really need to swap to a bolt on version. Problem is they are all not tall enough. You still get 1mm gap too and bottom.
What do y’all think of using a 3D printed part like these?
Offline Lectroid
Re: IEC inlet spacer plate
« Reply #1 on: March 14, 2026, 11:21:28 am »
I prefer the bolt-on myself, but I think your mating flange idea should work okay.  :icon_biggrin:
Magis bos clocca!
Free Beer Tomorrow!
Offline Blooze
« Reply #2 on: March 14, 2026, 12:04:21 pm »
Me too. This is the first chassis I’ve had with a snap-in. I really just want the hole completely covered when I go to a bolt-on. I don't think the flange needs to be separately bolted to the chassis since the two bolts for the IEC will still be going through plenty of aluminum. Having the plates made with a harder/stiffer plastic would probably help too.
« Last Edit: March 14, 2026, 03:50:43 pm by Blooze »
Offline RoadShow
  • Disturbing the Peace Since 1955
« Reply #3 on: March 14, 2026, 08:49:57 pm »
I've used these several times and like the fuse being incorporated.  As long as you don't get crazy sloppy the hole gets covered.
https://www.amazon.com/dp/B01GBW8J8A?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_4
Offline Blooze
« Reply #4 on: March 14, 2026, 09:08:33 pm »
I’ve used those too. This amp is already made, unfortunately, so I don’t really want to start cutting and filing holes. The snap-in one is in there and relatively solid, but it still moves around more than I’d like and I don’t think I want to trust it long term to not pull out.
