September 08, 2026, 04:41:01 pm
Hoffman Amps Forum image Author Topic: JCM2000 Blowing Fuses  (Read 4880 times)
Offline dpm309
    • Matthews Amps
« on: March 19, 2026, 02:01:41 pm »
Have a JCM2000 dual super lead that keeps blowing fuses. Pulled all the tubes and powered on (using a light limiter) and it still showed a short. Disconnected the secondaries and the light dimmed after a couple of seconds. I am now suspecting that the rectifier might be bad. This is a SS rectifier and I checked the 4 diodes (D7, 8, 9, and 10) and they are all showing ~.5 VDC in the forward position and OL in the reverse position. I tested these while still connected to the circuit. I have not pulled the boards to see if there are any issues. I do not see any indication of burning/overheating. What else should I be looking at?Thanks, Dan
Offline dpm309
    • Matthews Amps
Re: JCM2000 Blowing Fuses
« Reply #1 on: March 19, 2026, 02:08:52 pm »
Here is the correct schematic.
Offline AlNewman
« Reply #2 on: March 19, 2026, 02:38:13 pm »
You only unhooked the HT leads?  Look for shorts across your filter caps, also across the output transformer primary.
« Reply #3 on: March 19, 2026, 02:41:39 pm »
which fuses, there's like 6
break the circuit at the X's do they still blow??
Offline stratomaster
  • Don't guess, measure.
« Reply #4 on: March 19, 2026, 07:39:39 pm »
Oh boy ...
This is likely the end stage of the conductive board syndrome.
There are a few 3rd party aftermarket boards you can install, but they may be cost prohibitive.
Barring that:
Sometimes the small 22pf cap from plate to cathode on the power tubes shorts.  Check for continuity between pins 8 and 3 on the socket. If you get anything, clip that cap out and retry.
« Last Edit: March 19, 2026, 07:42:14 pm by stratomaster »
Offline dpm309
    • Matthews Amps
« Reply #5 on: March 20, 2026, 02:19:49 pm »
It was the HT fuse that blew. It was the HT leads that I disconnected when testing with the light limiter. Disconnected the 2 red leads also and am not getting the light limiter to light up at all. Reconnected the red leads and still not getting the limiter to light up at all.  I am getting 370 VAC from the HT connections, 7.2 VAC from the red leads (heater?), and 22VAC from the black and white leads (bias?). Cannot find a Marshall transformer diagram that matches the one I am working on. It looks like the PT was replaced at some time in the past.
Offline dpm309
    • Matthews Amps
« Reply #6 on: March 20, 2026, 02:46:42 pm »
 Stratomaster, I am not finding the 22pf cap for the power tubes. Not shown in the schematic. I have replaced a new board on a DSL100 a couple of years ago that had a bunch of burnt traces near the power tubes. Antique Electronics sells them for about $200 and it brought the amp back to like. Took about one hour to replace. Don't know if I want to go that route yet.
Offline dpm309
    • Matthews Amps
« Reply #7 on: March 20, 2026, 03:16:32 pm »
Here is a picture of the PT.
« Reply #8 on: March 20, 2026, 05:30:59 pm »
Did you check for continuity between 3 and 8? If there's nothing, then don't worry about the cap.
Regarding the board, try to find one now.  They have been discontinued and sold out for a few years now.
Offline AlNewman
« Reply #9 on: March 20, 2026, 05:34:07 pm »
Seems like an awful lot of rust in that amp.  If it was me, I'd spend some time cleaning everything before even plugging it in.
