September 08, 2026, 04:42:07 pm
Hoffman Amps Forum image Author Topic: Tube Preamp SMPS  (Read 8003 times)
Tube Preamp SMPS
« on: May 01, 2026, 06:39:51 pm »
Nifty little DC-DC converter - 9V > 250V + 6.3V - Rated at 250V 15mA / 6.3V @ 1.5A. Works really well. Have a 12mA R load on the HT (22KΩ 6.5W R), and about 1A on the 6.3V output. Pics in link. Performs well, about 100-150mV ripple on the HT output. link to part on Amazon. Beware, that the power source (5.5mm x 2.5mm jack) the tip is (+), and not tip (-) like for pedals. May build a guitar pre with it. Use a polarity inverting cable to use pedal wall-wart.
Link to pics.
Link to SMPS on Amazon.
--Pete
Offline Jonas
Re: Tube Preamp SMPS
« Reply #1 on: May 03, 2026, 08:08:52 am »
THANKS PETE!!! I HAVE A COUPLE ON ORDER
« Reply #2 on: May 03, 2026, 02:17:54 pm »
 :smiley:
Offline Jonas
« Reply #3 on: June 06, 2026, 11:48:05 am »
Pete, what was your approach to eliminate the switching noise? Do you have any recommendations of things to try?
thanks!!!
« Reply #4 on: June 08, 2026, 03:08:09 am »
Tamed it with a with a pair of Pi filters - The first iteration I used a single 20H 10uF Pi filter, was ok, but still had some pop/buzz - Added a second Pi filter with 100uH 4.7uF, fixed most of the noise. Not perfect but tolerable and usable. Has about 23-30mV of ripple now, down from about 150mV average. I wound the toroid myself - Had some ferrite cores from a lab that was shutdown, so wound a  Micrometals T68-3 with 25 turns of 24AWG, salvaged and stripped wire from an old ethernet cable. No, you don't need 1W Rs in HV string, that's what I had in the bins.
Schema attached.
Pic of ripple measurement of B+ line - Link below.
https://www.dropbox.com/scl/fi/z9kjf10i7owtmwhq1g5ot/IMG_20260608_021259634_HDR.jpg?rlkey=xgynz75541ry58kwv7kcrz7vc&st=fjdakbg0&dl=0
--Pete
EDIT: The 1W resistors in my application are overkill, my circuit draws about 3mA total. YMMV - Depends on the PS current load.
« Last Edit: June 08, 2026, 03:12:01 am by DummyLoad »
Offline Jonas
« Reply #5 on: June 09, 2026, 08:47:46 am »
test
Offline Jonas
« Reply #6 on: June 09, 2026, 08:51:17 am »
thanks Pete and nice job! - I will give that a try
Are you getting any noise form the 6.3v heaters?
I an not using the on-board dc jack, wiring direct (tried to upload a pic no success - attachment options is not working for me???)
Offline Jonas
« Reply #7 on: June 16, 2026, 04:57:55 pm »
I didn't have room for large chokes inside my design so I'm going to try a different approach. I read that a darlington pair configuration could be used to create a buffer for the HT. Has anyone tried this?
