September 08, 2026, 06:46:29 pm
Hoffman Amps Forum image Author Topic: Selmer Zodiac Twin 30  (Read 25100 times)
Offline johnfromcyrene
« on: May 11, 2026, 01:44:01 pm »
Hello,
Was looking to do a single channel zodiac twin 30, the amp from house of the rising sun. Was looking to make it a single channel with rotary control only instead of the click buttons and to combine the preamp and power into a single chassis.
Re: Selmer Zodiac Twin 30
« Reply #1 on: May 11, 2026, 06:33:10 pm »
Started here. Will clean it up
« Reply #2 on: May 12, 2026, 08:41:47 am »
I've stitched together a single page schematic. Hope this is what you wanted...
« Last Edit: May 12, 2026, 11:31:26 am by sluckey »
« Reply #3 on: May 12, 2026, 12:19:13 pm »
yes thank you.
« Reply #4 on: May 12, 2026, 12:56:29 pm »
This is an interesting looking schematic. If I had run across this schematic 10 years ago I would have built it.
Not convinced this amp was a major contributor to the Animals' sound. I think it was probably just the amp they had in hand. The AC-30 or AC-50 would probably have performed just as well.
« Reply #5 on: May 12, 2026, 01:15:27 pm »
In the click tone buttons I notice what appears to be a choke in there. Do you know why that is there?
« Reply #6 on: May 12, 2026, 01:18:59 pm »
Don't call it a choke. Just call it an inductor. Inductors can affect tone in a very similar way that capacitors do.
« Reply #7 on: May 12, 2026, 01:24:09 pm »
Ok I see.
« Reply #8 on: May 12, 2026, 02:10:08 pm »
I'll probably do a layout for this amp when I get all my house chores done. Could be a while.
« Reply #9 on: May 12, 2026, 03:58:34 pm »
Great, You will have a better layout then mine I think. Will wait for that.
One thing I cant figure out is this part here, does this go into the tone pot when rotary control is engaged? Or is that part of the high treble? Im not sure what this does.
« Reply #10 on: May 12, 2026, 05:04:50 pm »
I left that cap/resistor out on purpose. This is what the schematic should look like.
« Last Edit: May 12, 2026, 06:16:52 pm by sluckey »
« Reply #11 on: May 12, 2026, 05:13:18 pm »
what does it do? give you more treble?
« Reply #12 on: May 12, 2026, 06:11:59 pm »
Probably. I left it out because Channel 1 did not have it.
Offline passaloutre
« Reply #13 on: May 12, 2026, 09:16:05 pm »
What does the filter after the first 12AX7 do? It almost looks like a fixed TMB tone stack.
« Reply #14 on: May 12, 2026, 10:35:50 pm »
I don't know. I just call it a tone network and try not to think about it too hard.    :icon_biggrin:
« Reply #15 on: May 12, 2026, 11:39:23 pm »
I think its a treble bleed circuit.
« Reply #16 on: May 13, 2026, 01:30:51 am »
May be someone will be interested on this (part one)
« Reply #17 on: May 13, 2026, 01:33:51 am »
May be someone will be interested on this (part two)
« Reply #18 on: May 13, 2026, 02:09:13 am »
May be someone will be interested on this (part three)
« Reply #19 on: May 13, 2026, 08:05:32 am »
Thanks for doing that Franco. That 2 pole 6 position switch makes it easier to see what's happening. A Hammond 154G should work for the 9.5H inductor.
« Reply #20 on: May 13, 2026, 10:01:05 am »
If a Hammond 154G is used I'll try to add, in series to it, a 270R (5% or better 1%) resistor + a 500R multiturn trimmer (with the purpose to decrease Q), then adjust the trimmer at your taste
« Last Edit: May 13, 2026, 04:13:24 pm by kagliostro »
« Reply #21 on: May 13, 2026, 07:10:01 pm »
is the inductor a big part of the sound? Can it be replaced with a cap?
« Reply #22 on: May 13, 2026, 07:19:33 pm »
Yes and no.
« Reply #23 on: May 13, 2026, 08:43:55 pm »
I think you need a footswitch to activate the tremolo. Is that right? is it hard to make the footswitch deactivate the tremolo so its always on or does that not make sense?
« Reply #24 on: May 13, 2026, 10:09:56 pm »
According to the schematic you do need a footswitch plugged in to enable the tremolo. But, all you have to do to be able to use the tremolo without the footswitch is replace the footswitch jack with a switching jack such as Switchcraft 12A and connect the switch lug to the ground lug.
« Reply #25 on: May 14, 2026, 12:08:04 am »
I see thank you.
« Reply #26 on: May 14, 2026, 02:04:37 am »
« Reply #27 on: May 16, 2026, 07:41:08 pm »
In the schematic there is a .01 and then .047 in ()
does that mean either one??
« Reply #28 on: May 16, 2026, 08:54:35 pm »
There is also a resistor that's marked 10K (22K). That crappy looking schematic shows .01 and 10K. Don't use the values in parentheses.
« Reply #29 on: May 19, 2026, 06:49:20 pm »
I put together a layout for the board. its not as good as the ones you do. Any plans for a layout?
« Reply #30 on: May 19, 2026, 07:37:02 pm »
I'm working on one. About 70% done. I've included a 6 position rotary switch to handle the function of the push button selector and I dropped the magic eye to use a red LED as a visual indicator.
Show me what you have. Here's the schematic I'm working with...
« Reply #31 on: May 20, 2026, 03:33:43 pm »
I put the schematic in kicad and then arranged the components on the pcb board with a ground plane on the back. Will probably just wait for yours because you know more then me.
« Reply #32 on: May 21, 2026, 03:42:44 pm »
Here are my drawings. I've included drawings for your original request (no tone selector) plus drawings for a cheap rotary switch instead of the push button selector. I included my choices for iron. I've proofread these drawings several times but sometimes errors just hide in plain sight. LOOK FOR ERRORS!
I'm never gonna build this so if you run with it just know that you will be the first to finish.    :icon_biggrin:
« Reply #33 on: May 21, 2026, 04:40:12 pm »
Ok thank you. For the EM84 magic eye. it says not used but I still put that tube in there?
« Reply #34 on: May 21, 2026, 04:54:01 pm »
You can if you want to. I also included a red LED that can be mounted on the front panel to be used for a flashing tremolo indicator. The magic eye looks a bit nostalgic. Some people like them. If you do use it, be sure to rotate the socket for best viewing angle BEFORE drilling mounting screw holes for the socket.
« Reply #35 on: May 21, 2026, 05:16:25 pm »
But if I dont use it then I delete that tube along with the two resistors the cap and the connection and the connection to the 330k resistor?
« Reply #36 on: May 21, 2026, 06:22:46 pm »
Correct.
Or you could install the circuit but just don't put a tube in the socket. The magic eye is monitoring the LFO tremolo signal. It is not connected to the signal path and will cause no effects.
« Reply #37 on: May 21, 2026, 08:29:08 pm »
Ok what happens if you put the tube in and have the led?
it wont cause any problems correct? they just both will flash?
« Reply #38 on: May 21, 2026, 09:05:42 pm »
The LED and magic eye will coexist happily together.
The LED simply flashes at the tremolo speed. So, it's an indicator that tells you the tremolo is on and you can see how fast it is. But the LED cannot tell you how deep the tremolo will be.
The magic eye has two green "lights" that pulse with the tremolo speed. But it is also sensitive to the depth/strength of the tremolo. Stronger tremolo will cause the two lights to actually pulse harder until they may even merge. This gives you an indication of how strong the tremolo will be. The depth pot will control the magic eye.
This video will demonstrate much better than words. The one on the right is the EM84
« Last Edit: May 21, 2026, 10:54:56 pm by sluckey »
« Reply #39 on: May 21, 2026, 11:04:32 pm »
And here's the amp. He turns the tremolo on at about 1:40...
« Reply #40 on: May 23, 2026, 06:58:01 am »
Is the purple wire in the following screenshot connected to the .068 cap here? Just want to make sure im reading it correctly. Also i assume its ok to move the other wire from the 220k to the .0047 cap as indicated with the arrow. It works better for my layout. Is that ok? its the same yes?
« Reply #41 on: May 23, 2026, 08:21:09 am »
Yes. Actually, there are two purple wires, one from the depth pot, the other to V3. This is labeled tremolo signal on the schematic.
That's fine. Both of those turrets are connected together with a jumper that runs beneath the node B cap.
It's good that you are studying and questioning the layout. Compare it to the schematic and you will have a better understanding how this amp circuit works. Let me know if you find any inconsistencies between the schematic and layout.
« Reply #42 on: May 24, 2026, 03:06:28 am »
Im putting mine on a pcb so thats how Im doing it. I have a ground plane on the back. I was thinking of puting a plane on the front for the nfb. That way I dont have to run a wire from the top if need be. Would you get any weird effects do you think from doing this? weird hum or anything.
« Reply #43 on: May 24, 2026, 08:50:33 am »
I have no interests or opinions about pcb design.
« Reply #44 on: June 21, 2026, 02:57:53 am »
Can anyone confirm if you can connect the 330k to the 6.8m instead of to the 22uf?
if not then perhaps to the 220k? next to it? it works better with my layout.
Offline passaloutre
« Reply #45 on: June 21, 2026, 08:29:05 pm »
This is all the same node
