September 08, 2026, 04:40:12 pm
Hoffman Amps Forum image Author Topic: Marshall dual monobloc EL34 50/50 - Cooling fan too noisy  (Read 3471 times)
Offline Yosser
« on: May 24, 2026, 12:38:22 pm »
Has anybody replaced the fan in this amplifier with a quieter cooling fan, if so what make and model did you use?
Offline nandrewjackson
Re: Marshall dual monobloc EL34 50/50 - Cooling fan too noisy
« Reply #1 on: May 24, 2026, 04:34:49 pm »
Do a search for the mesa boogie cooling fan used in several models.
Offline Yosser
« Reply #2 on: May 25, 2026, 08:32:15 am »
The model of fan is Sunon kd2408ptS1 24vdc 1.6w 40cfm 33db  P/N 13.A.GN
No longer available
https://uk.rs-online.com/web/p/axial-fans/1118358?msockid=07ae167ec7b0634d0bf30003c6a562ce
I would be looking for an equivalent but noiseless if possible.
Offline acheld
« Reply #3 on: May 25, 2026, 09:41:04 am »
I've used several different computer cooling fans w/o difficulty.  They are pretty quiet.  Many of them come with a variety of inline resistors to limit speed, but it is easy to dial in your desired speed as needed.
Offline Rontone
  • Ixnay on the Ampscray
« Reply #4 on: May 25, 2026, 09:47:40 am »
I was just going to say computer fans, but if your in the UK and ordering from RS check out EBM Papst fans,
I used to work at a Power Amp company and that's what we stocked, they were pretty good, and very quiet
Check them out on RS versus your Sunon for airflow and dB ratings, their about a similar price too, just a little more
Offline Yosser
« Reply #5 on: May 25, 2026, 12:25:44 pm »
I had a look a them before and the db rating compared to the Sunon, I couldn't ascertain whether 30db or (33db in the sunon) is actually quiet loud or not.
I know the one in the marshall amp is loud to the point that it may be a malfunction and as I am considering selling the amplifier it's a bit of a concern.
You would not notice it at band volume levels but it could be a nuisance in a recording situation.
I had considered using it as a stereo playback amplifier but that fan noise is a no no.
Offline Rontone
« Reply #6 on: May 25, 2026, 12:44:28 pm »
If its really that loud then maybe it is getting a bit tired and rattling like my PC at the moment!
30dB is around the normal level for most of those sizes of fans I can imagine, seems that way when I'm looking at PC fans
I can recommend Noctua branded fans too, unsure if they come in 24V though, although you could alter that I suppose...
But if you are thinking of selling it then just something good and branded and reliable will do, the standard Sunons from RS are around £10 each
Offline glass54
« Reply #7 on: May 25, 2026, 06:49:45 pm »
Hi Yosser
Glad you mentioned your old fan was Sunon!
I found them to be very good, relatively well priced and very acceptable noise level, so if you can get another, go for it.
If you want really quiet, PAPST make a range but $$$.
I have never heard a Mesa Boogie Fan that I could be in the same room as the amp!! is it because we use 50Hz  :l2: :l2:
By the way, around 30dB SPL (A) is getting into the Pro recording studio background noise (25dB SPL being a good target).
Regards
Mirek
"To measure is to know"
Offline JPK
« Reply #8 on: May 27, 2026, 07:46:47 am »
Take a look at BeQuiet! brand of pc fans. Almost complete silent operation.
I love tubes
