September 08, 2026, 03:49:10 pm
Hoffman Amps Forum image Author Topic: 5E3 heater wires @ low voltage    (Read 5988 times)
Offline Geezer
« on: June 18, 2005, 06:07:51 am »
        > 5E3 heater wires @ low voltage
<< Prev Topic | Next Topic >>
Author  Comment
roomnoise
Junior tube assistant
(4/4/04 4:51 pm)
 I just began testing my delux amp built from scratch and using a hoffman board. Nothing is working properly.
First issue is that the heater wires are reading around 3volts AC. Is this a PT problem?
I am using mercury magnetics Axiom transformers for both power and output. I have gone over the layout diagram a million times and everything is connected properly. The PT has a filimant center tap, which I star grounded. The latter is the only difference that I can find with my amp and the diargram (which uses the two resistors.) (note: I set up the amp in series with a 100 Watt bulb, as was suggested. Although the caps fully charged, the bulb never lit up i.e, a leak??)
HELP please.
zachsdad
(4/4/04 7:17 pm)
 low heater voltage
 What kind of voltages are you getting off of the HV windings and the Recty filiament windings
Les
 Topic Commands
Powered By ezboard® Ver. 7.32
