September 08, 2026, 04:42:00 pm
Hoffman Amps Forum image Author Topic: Safe to power an amp with a home backup battery?  (Read 4068 times)
Offline jacobarber
« on: June 11, 2026, 12:31:48 pm »
I'm just throwing out a hypothetical. I have a couple of EcoFlow Delta2 batteries and was wondering if there are any concerns about using one of these to (temporarily) power an amp. So long as it can essentially provide a really clean 1800w, 120VAC @60Hz on a 13A circuit.
Offline passaloutre
Re: Safe to power an amp with a home backup battery?
« Reply #1 on: June 11, 2026, 02:53:06 pm »
I don't see why not, if it's clean and has the power capacity. A tube amp is just an inefficient space heater.
Offline JPK
« Reply #2 on: June 12, 2026, 10:01:14 am »
I've run my amp on my ECO Flow Delta Pro 3 backup system. Worked fine.
I love tubes
Offline stratomaster
  • Don't guess, measure.
« Reply #3 on: June 14, 2026, 09:10:43 am »
If you have an oscilloscope then check the output of the inverter to make sure it is a reasonably clean sine wave.  Quite a few are triangular or include voltage spikes that could pose a noise or thermal issue with the amp when used long term.
