September 08, 2026, 06:50:23 pm
Hoffman Amps Forum image Author Topic: Nfb and lack of presence jtm 45  (Read 7288 times)
Offline Snake5150
« on: June 27, 2026, 04:43:36 pm »
Been a while since I’ve been on here as life has got busy. Moved , had a kid, but finally got time to look at the amp again. Built a triode jtm50 black flag clone, sounds great, learned a ton thanks in part to yall.
The presence control does like nothing at any volume. I flipped the amp today and discovered that I put the 16 ohm ot tap on the nfb resistor downstream, and only use the 8ohm. THERES THE LACK OF PRESENCE DUMB A**. So am I correct in thinking, remove the 16 ohm tap, and wire from the nfb resistor to the output 8ohm tip.
And if it squeal the primary are reversed. Thanks fellas!
« Last Edit: June 27, 2026, 04:49:18 pm by Snake5150 »
Re: Nfb and lack of presence jtm 45
« Reply #1 on: June 27, 2026, 05:04:36 pm »
The first real JTM45s had the NFB connected to the 16Ω tap. The 16Ω tap should give you more Presence control than the 8Ω tap. This Presence control is kinda subtle and will sound scratchy as the pot is turned.
Is the 5K pot wired correctly? Is the NFB resistor 27K?
« Last Edit: June 27, 2026, 05:07:57 pm by sluckey »
Offline Snake5150
« Reply #2 on: June 27, 2026, 05:08:14 pm »
It sounds like nothing. From zero - 10 on the pot at even moderately loud volumes. Would it hurt the amp to connect the 8 to the nfb resistor, my layout actually shows this but for some reason 2 years ago I didn’t do it.
« Reply #3 on: June 27, 2026, 05:24:30 pm »
You can try the 8Ω tap but I don't expect that to change anything. Are you sure the speaker jack is wired correctly? I ask because it's unusual to see a yellow common wire from the OT. Also check the 27K NFB resistor as well as the presence pot.
Offline Snake5150
« Reply #4 on: June 27, 2026, 05:28:12 pm »
The pot and jack wiring seem correct. The layout shows the common to the jack. The resistor reads weird but has the 16 tap still attached
« Reply #5 on: June 27, 2026, 06:52:52 pm »
I see a yellow OT wire connected to the jack sleeve. But is the yellow lead really the OT common? And where is the jack sleeve actually connected to chassis?
You would have to disconnect one of the resistor leads in order to get an accurate reading.
Offline Snake5150
« Reply #6 on: June 27, 2026, 07:03:30 pm »
The yellow wire is common. The ground goes to the chassis star ground,The pot has pin1 ground and 3 nfb in, that may be wrong
« Last Edit: June 27, 2026, 07:07:55 pm by Snake5150 »
