September 08, 2026, 04:42:11 pm
Hoffman Amps Forum image Author Topic: Kay 703 grouding scheme and crazy squealing  (Read 10614 times)
Offline choosebronze
« on: July 19, 2026, 08:42:53 pm »
I had most of the parts to build a Kay 703, including an old 6" combo amp willing to donate its cabinet and speaker. So I figured I'd build one for my daughter to have a little practice amp. And boy has it been a learning experience...
The original schematic shows T1 but I gather from prior posts that T1 wouldn't have been a true isolation transformer. I replaced that with a Triad N68X in my build. Other than that, adding a fuse, and deleting two of the input jacks, I built the amp just like the schematic. I read another post where Sluckey recommended adding an isolation tranny to a widowmaker and he showed what I would've basically expected, just dropping an isolation tranny between the hot and neutral wires with no other circuit changes.
But I'm getting stuck. I've built a bunch of amps and I feel like I understand that power scheme well, but the isolation transformer is really throwing me for a loop. The N68X has two secondary wires and a shield wire. Shield goes to the chassis/safety ground. The other secondary wires confuse me more. I originally had them wired the way I'd wire any other PT (they were wired as a series heater string and rectifier pin 5), but that gave me very weird voltages and no audio. So instead I wired a secondary wire to pin 5 of the rectifier. The other secondary wire sent to chassis ground, and redid the heater wires, just like it's drawn on the schematic. I don't.... exactly understand. It seems like that would've electrified the chassis? But in any event, that worked and the amp now plays. So something about that must be right even if I don't understand what it is.
Now I do have guitar audio, but I also have an incredibly loud squeal. Not a little hum. Not a "noisy" amp. Full on screeching that changes with the volume and tone controls. Happy to upload audio if you need a laugh. I went to ask AI about that (I know, sorry sorry) and it confused me even more!
It said that I don't want any part of my circuit touching the chassis anywhere - true "isolation," which I guess makes sense. That all "grounds" - my PT secondary return, input jack, all ground points in the circuit, everything, should go to one floating "ground" point that never touches the chassis. And the only things that should go to the chassis are the earth safety ground and the PT shield wire.
I'm now very confused, and very much not wanting to accidentally shock myself. Like I said, I'm comfortable working on a standard amp but I feel like I have to quadruple check everything with thxis thing because the electricity isn't necessarily where I expect it to be.
I am incredibly grateful for any help or advice you guys have.
« Last Edit: July 20, 2026, 12:21:08 am by choosebronze »
Re: Kay 703 grouding scheme and crazy squealing
« Reply #1 on: July 20, 2026, 12:20:53 am »
Okay I reread Rob Robinette's article on widowmakers for like the 4th time. And I read a couple more articles about converting antique radios to isolation transformers. I'm actually thinking I wired the PT the correct way.
I did some chopsticking and moving the wires around definitely changes the squealing, and turning the pots does too, big time. So I think a wiring problem is more likely. But anyway, here's what this craziness sounds like: https://limewire.com/d/oPfwo#T0VhQu8Isf
Offline AlNewman
« Reply #2 on: July 20, 2026, 02:06:04 am »
I don't think you want your heater transformer to connect with your B+ at all.  I do think you need a ground reference for your heaters.
Do you have a schematic as you have it wired currently?
« Last Edit: July 20, 2026, 02:09:01 am by AlNewman »
« Reply #3 on: July 20, 2026, 09:41:59 am »
The attached file shows how to connect the Triad isolation transformer to provide complete isolation. Notice the two primary windings are connected in parallel.
There is no need to change any wiring on the original schematic.
« Reply #4 on: July 20, 2026, 10:55:51 am »
Ooh, okay. Thank you Steve, that makes sense. So then 2 questions.
1. If I'm building the stock circuit with the Triad in front of it, do you have a suggestion for what I should use as T1? Thus far I'd been using the Triad in place of T1, not in front of it.
2. When built as you've shown, I assume the chassis remains my ground, and all of the floating ground stuff AI mentioned is bunk.
« Reply #5 on: July 20, 2026, 12:01:41 pm »
That original amp is mostly safe to play just as is. Just add a 3-prong power cord with the green connected to ground. The only issue is the filament circuit is still connected to AC line. It's really only an issue if the filament circuit becomes shorted to chassis, but that's not dangerous to the player. Just might trip the house breaker. So, it would be a good idea to isolate the filament circuit from the AC line. You could do it as shown in my schematic. Or you could just use the second iso tranny to only power the filaments. Connect both red wires to the series filament string and also connect one of the red wires to chassis. Now you have everything safely isolated from AC line and the filament circuit is referenced to chassis ground which may help with any filament hum.
Still requires two iso trannies. I don't know what AI told you, but there is no reason to float all your grounds.
Your sound clip indicates a problem in the amp. Most likely a wiring error. We need to see a schematic of your actual circuit. Hi-rez pics of the actual amp may be useful too.
EDIT... added schematic
« Last Edit: July 22, 2026, 06:07:45 pm by sluckey »
« Reply #6 on: July 29, 2026, 12:32:01 am »
Thanks Steve, before I saw your updated post with the second schematic I sort of went down a rabbit hole of how to make the amp 100% safe since I’m giving it to my 7 year old daughter.
I looked in the drawer and saw an old Thordarson 6.3v PT and I started thinking... Which is never good.
I ended up running the B+ with half wave diode rectification fed from the n68x.
Then I also tapped those primaries and fed the 6.3v PT and subbed the tubes for 6AU6, which I had, and a 6DG6, which was $4 shipped on eBay. Wired the heaters up like a normal amp. I have no idea if what I did was smart. But everything seems safely isolated now and the amp sounds great.
As for the squealing I just messed with the lead dress a lot and shortened every run that could be shortened and that solved the problem.
Thanks for everything, as always!
« Last Edit: July 29, 2026, 12:37:17 am by choosebronze »
« Reply #7 on: July 30, 2026, 03:23:46 pm »
I hate when I find an old forum post with a solution and no one shares the final product. I can't imagine anyone is ever going to want to build a Kay 703 from scratch. I'm the only one weird enough for that. But just in case someone is curious one day, here's the final. The crunch of this amp when it's cranked is actually pretty great. I look forward to recording with it.
I also had a random 100u 160v cap so I threw it in as a third filter stage. Totally optional, but that might be why this cheap little circuit is dead silent when I'm not playing?
