August 26, 2026, 04:43:14 am
Hoffman Amps Forum image Author Topic: Copicat IC400 Vari Speed, speed stuck on full...  (Read 14765 times)
Offline Rontone
  • Ixnay on the Ampscray
« on: July 22, 2026, 04:30:38 am »
Just repairing a spare Copicat I picked up, was dead so went through the power supply and the rectifier was blown and the internal fuse, sorted that out and got it running
But the motor [in this case its the model with a DC motor] is stuck on full speed, potentiometer is fine and the internal trim pot doesn't alter it
There is a transistor on the incoming power [TR101= RCA 40871 or BD303 in my case] and the IC101 741 chip seems to be adjusting the DC to the motor?
I'm presuming its the 741 IC as full power is coming through to the motor so I think the transistor is working
Which points on the schematic attached would be good to test what happening here, or not happening!
Re: Copicat IC400 Vari Speed, speed stuck on full...
« Reply #1 on: July 22, 2026, 07:49:41 am »
looks like pin 3 should have a vdc that changes with the vari-pot,  use chassis as ground ref for measuring.
you've verified the 15vdc that feeds the vari-pot?
« Reply #2 on: July 22, 2026, 09:03:58 am »
Shorted TR101 needs to be high in the suspect list. Remove from circuit and check for low resistance reading between emitter and collector.
Offline Rontone
« Reply #3 on: July 22, 2026, 11:25:09 am »
Thanks for the replies, I went for some lunch and then sat down with this again,
I was about to order some 741 IC's but then realised I did have one in an fx pedal so tried that and its working fine!
Getting a smooth change of DC, with the internal trim pot you can set it real slow
So whatever took out the rectifier may have damaged the IC, or the other way round
Motor now needs a bit of a clean but its working pretty stable even with the original drive belt, I've recapped most of it, just crackly pots left to clean
Offline Rontone
« Reply #4 on: August 19, 2026, 08:35:39 am »
So, the unit mentioned above is even better after cleaning and bedding in a bit
Now I'm onto the last one to overhaul, so I get two for myself and one to sell off
It had a motor control circuit fault just as the one above, but not stuck on full, this was power oscillation in the motor DC supply, almost like a sawtooth LFO, rising up then falling away quickly [it was a nice seasick vibro-flange effect if it could be put on a switch!]
So as before I imagined it could be the IC 741 or TR101, I had ordered some of these transistors last time just in case, removed the old BD303B and it had no short across B,C or E, but measured incredibly low on my tester compared to the spec and the new replacement I had, an hFE of 10 and Vf = 580mV. The legs were quite heat tarnished so it had been running hot at some point...
Then I replaced TR101 with a tiny bit of fresh heatsink compound and cleaned all the fixings and its now working great,
The way it was rising up to full power then falling away, at first it made me think the motor or belt was slipping etc, but it seems to be not enough juice to get the motor torque required, so what could that be? Is that a current issue as the transistor starts to fail or age?
« Reply #5 on: August 19, 2026, 09:46:45 am »
what could that be?
let the sleeping dogs lay
i've found that "knowing the answer" this time, only messes up your ability to fix it next time  :icon_biggrin:
