July 28, 2026, 02:43:25 am
Hoffman Amps Forum image Author Topic: Cathode follower with a plate resistor  (Read 179 times)
Offline separateness
  • dallier
« on: July 26, 2026, 08:18:44 pm »
Any of you fellas ever seen a cathode follower with a plate resistor?  See attached pic of an oil can unit schematic.  I have a similar unit with a different branding and basically electronically identical except for that resistor and cap on the plate of the cathode follower. I was just wondering why they'd gone and done that.
Re: Cathode follower with a plate resistor
« Reply #1 on: July 27, 2026, 08:59:03 am »
What tubes are those?
« Reply #2 on: July 27, 2026, 09:59:49 am »
one tube. 7199
« Reply #3 on: July 27, 2026, 02:25:59 pm »
Standard grounded cathode amp, not a follower per-se. Signal tapped for lo-Z, low level output from from cathode. Like follower, output phase follows input phase.
EDIT: is also summing point for dry signal path.
--Pete
« Last Edit: July 27, 2026, 04:48:58 pm by DummyLoad »
  • dallier
« Reply #4 on: July 27, 2026, 04:25:00 pm »
one tube. 7199
Correct, I should have said this to begin with.
--Pete
What exactly is the distinction there?  The presence of a plate resistor?
How does performance differ? Is the gain diminished witht the plate resistor?  I would assume so but what do I know. The echo recovery on my unit is identical aside from the plate resistor and cap.  Do you it would be an improvement to implement the resistor and cap there?
