September 06, 2026, 12:47:00 am
Hoffman Amps Forum image Author Topic: DC to AC Inverter  (Read 30 times)
Offline dpm309
    • Matthews Amps
DC to AC Inverter
« on: September 05, 2026, 02:09:04 pm »
I want to construct or buy a simple DC (9 or 12 Volts) to AC (120 VAC) to power a small water pump on a fountain. Want to place the fountain in an area that lacks any nearby AC outlets. Have been looking online and have not been able to find what I am looking for. Could I just reverse say a 9VDC power supply? Any ideas?Thanks, Dan
Re: DC to AC Inverter
« Reply #1 on: September 05, 2026, 02:34:43 pm »
You can't just reverse a power supply. But Amazon or WalMart have plenty if small inverters...
     https://www.amazon.com/s?k=dc+to+ac+inverter+500w
     https://www.walmart.com/search?q=dc+to+ac+inverter+500w
Offline dpm309
    • Matthews Amps
« Reply #2 on: September 05, 2026, 02:56:22 pm »
Yeah, I thought that would not work. Will check out Amazon and Walmart.Thanks,
« Reply #3 on: September 05, 2026, 03:51:40 pm »
been using these folk for 20 years with my solar array, bit overkill for your needs although i did find a good deal there on a 100W panel n charge controller to do basically what you're doing, I have a 55gal water tank n 12vdc pump for watering the garden.
 https://www.aimscorp.net/product-category/dc-to-ac-power-inverters/
