September 08, 2026, 03:37:44 pm
Hoffman Amps Forum image Author Topic: First amp build (5F1) would anyone mind double checking my turret board layout?  (Read 98 times)
Offline HexEnduction
Hi there, first time long time! I've built about a dozen pedals in the past year and I'm really excited to be jumping into the amp world. I'm working off the 5F1 Mojotone kit and I just finished up adding all of the turret board components (still need to solder/add the offboard wiring). I checked over my work a few times but I'm paranoid that I'm missing something or that I messed something up... if anyone would be so kind, could you take a look and let me know if this looks alright? Open to any suggestions or potential improvements as well.
A couple of things to note: I moved the 16uf cap furthest left up a bit on the board as otherwise it would cover up the mounting hole (the hole isn't visible in the picture I snapped)... I didn't want to have the cap sitting on top of a screw. I also pushed that blue 10K cap at the bottom left upwards a tad so that I can more easily solder the turrets without inadvertently burning the resistor. I tested each component before installing them, everything is looking good on that end.
Wiring diagram:
My board:
Thanks so much!
don't forget the jumper 'tween the 2 8uF's grounds
Ah! I meant to go back and add the two jumpers at the top... I got so focused on double checking the components themselves that I completely overlooked them. I'll be adding them. I really appreciate it!
Offline ac427v
I would prefer to see a flameproof resistor for the 22k power rail dropping resistor.
Also a little more space between the 500 ohm/5 watt cathode resistor and other components to prevent possible overheating.
« Last Edit: September 08, 2026, 07:33:21 am by ac427v »
The 22k power rail dropping resistor is 1/2 watt but searching around for ones I can only find 1w 22k metal oxide resistors so far. Just to double check, using a 1 watt resistor here would be no problem right?
And I'll add some more space between those components.
Thanks a bunch for the suggestions.
Hoffman sells 22K 3W metal oxide. However, according to the schematic there is 45V dropped across that 22K. So, the power dissipation is less than 0.1 watts. A 1/2W resistor will last forever.
