September 19, 2026, 08:12:03 pm
Hoffman Amps Forum image Author Topic: AB763 clone reverb hum - Help!  (Read 2256 times)
Offline VintageRob
« on: September 11, 2026, 09:55:39 pm »
Hi everyone - Apologies in advance for the long post.
A number of years ago I built an AB763 Deluxe Reverb clone using Leo’s layout including the brass ground plate, preamp and power amp grounds separated etc. (some minor mods switchable NFB and tweaking the normal channel tonestack). While always happy with the tone, I was never fully satisfied with the noise floor particularly when the reverb level was turned up high as there is a noticeable 100hz hum (mains here is Australia is 240V 50hz)
Having recently retired and having more time on my hands, I have spent the past few weeks searching this, and other forums trying various solutions but to no avail so I’m hoping someone more knowledgeable than I might be able to point me in the right direction.
Basically with all controls to zero (and the reverb return input to V4 shorted to ground) the noise floor is not too bad. The FFT app on my iPhone shows a 100hz peak of around -80db which shows as a peak to peak hum signal of approx. 10-15mv at the speaker output.
With the Reverb level turned up to 10, the 100hz hum level increases to approx. -63dB equating to around 30mv peak to peak at the speaker output.
Not having access to any AB763 clones or Fender Deluxe Reverb amps to compare, I could of course be ‘chasing a ghost’ and maybe some level of hum associated with the reverb is to be expected although I see comments on other builds indicating they have ‘zero hum’. I accept that there will always be some level of background ‘hiss’ introduced with a reverb circuit.
Below is a summary of my diagnosing so far:
1. Unplugging the reverb tank and grounding the reverb return (i.e. V4 grid) does NOT change the level of hum.
2. The amount of hum is controlled by the Reverb control.
3. Lifting the connection from the .033 cap to the Reverb pot eliminates the hum, confirming the V4 recovery stage is the source of the hum.
4. Swapping V4 with 3 other Tung Sol 12AX7’s does NOT reduce hum.
5. Replacing the lead from reverb return RCA socket to grid of V4 with shielded cable does NOT reduce hum.
6. Isolating the Reverb return RCA socket from chassis and connecting the ground to the point where V4 cathode electrolytic grounds to the brass grounding plate does NOT reduce the hum.
7. Doubling the filtering on the B+ node that supplies V4 does NOT reduce the hum.
Apart from being almost 100% certain the hum is being introduced in the Reverb recovery stage I am somewhat frustrated and totally out of ideas.
If anyone has any thoughts or suggestions I would be extremely grateful.
Cheers Rob
« Last Edit: September 12, 2026, 02:38:15 am by VintageRob »
Offline ac427v
Re: AB763 clone reverb hum - Help!
« Reply #1 on: September 12, 2026, 08:17:22 am »
Your troubleshooting has eliminated many of the common causes of reverb hum.
Older tubes in the reverb return circuit can cause hum. I always use a 220 U capacitor instead of a 22 U on the cathode of the reverb return to prevent this issue.
Offline Lectroid
« Reply #2 on: September 12, 2026, 11:26:49 am »
I also built a faithfully stock DR ab763 close and it does have a small amount of idle reverb noise.  But nothing you can hear once the volume goes up.  Yours sounds worse.  ac427v's idea of upping up the cap value makes sense to me.  I'm going to try that--(being in pursuit of Perfect Silence like all builders.)
[deleted]
« Last Edit: September 13, 2026, 11:48:46 am by Lectroid »
Magis bos clocca!
Free Beer Tomorrow!
Offline Helmholtz
« Reply #3 on: September 12, 2026, 02:21:55 pm »
100Hz hum is power supply ripple.
A tube can only cause 50Hz heater hum.
What happens, when you disconnect the cathode resistor and its bypass cap from the recovery triode?
Apart from that, I don't trust phone sound spectra, because of the poor frequency response of the built-in microphone. In reality the 50Hz peak might be much larger.
Please post a scope pic of the output hum.
Offline VintageRob
« Reply #4 on: September 15, 2026, 07:10:51 am »
Hi guys appreciate the guidance. I will try the suggestions regarding the reverb recovery bypass cap and report back. Cheers.
« Reply #5 on: September 15, 2026, 10:05:56 am »
The reverb recovery circuit has to deal with the smallest signal in the entire amp (even smaller than the signal at the input jacks). Using the correct tube sometimes becomes critical. Fender specifies a more expensive low noise/hum 7025 rather than a 12AX7 for the reverb recovery/mixer. Certainly worth a try.
Notice that V4a and V4b cathodes share a single 820Ω/25µF. Some people report better performance when using individual 1.5K/25µF for each cathode. Hoffman does this on his AB763 amps.
Offline Helmholtz
« Reply #6 on: September 15, 2026, 11:23:07 am »
Good point!
Sorry for missing that.
So my simple idea of only disabling the recovery triode by disconnecting its cathode won't work.
Rather V4b would need a 1.5k cathode resistor with bypass cap to keep it working.
Scope pic could help to identify the type of hum.
The waveshape will tell if it's mainly power supply ripple or heater hum.
(Of course V4 should always have its tube shield on.)
« Last Edit: September 15, 2026, 11:44:53 am by Helmholtz »
« Reply #7 on: September 16, 2026, 12:05:36 pm »
… when the reverb level was turned up high … a noticeable 100hz hum (mains here is Australia is 240V 50hz)
… with all controls to zero (and the reverb return input to V4 shorted to ground) the noise floor is not too bad. The FFT app on my iPhone shows a 100hz peak of around -80db which shows as a peak to peak hum signal of approx. 10-15mv at the speaker output.
With the Reverb level turned up to 10, the 100hz hum level increases to approx. -63dB equating to around 30mv peak to peak at the speaker output…
2. The amount of hum is controlled by the Reverb control…
So there is some hum there with reverb level pot cut completely, but more hum when you ‘add reverb’?
That is normal if you have hum in the dry signal. The reverb circuit sensitivity to noise will amplify any hum that’s already present.
I take it you swapped V1 and or V2 (in case you have a hummy tube there)?
Offline VintageRob
« Reply #8 on: September 16, 2026, 10:19:48 pm »
Thanks for the additional comments guys.
Helmholtz you are correct about the accuracy of the FFT app. I have spent a long time thinking it was 100hz hum however your comment led me to rethink this, and by comparing the hum I am getting with a 50hz tone from a tone generator app it is now apparent me that it 50hz not 100hz hum that is predominant.  :think1:
Tubeswell I forgot to mention there is a slight hum when the Volume control is at zero. Not having anything to compare it with I assumed that some slight hum and noise was inevitable with a tube amp?
As I have removed the Reverb drive circuit from the equation by disconnecting the return cable from the tank and grounding the input to the recovery tube, I assume the additional hum when increasing the Reverb level knob is coming from the Reverb recovery circuit.
Is my logic correct?
Sluckey thanks for the tip regarding using a 7025 in the V4 position. I don't have one to try but will look into where to source one.
In the meantime, if any members have built a Deluxe Reverb clone (AB763) do your builds have any hum at all particularly when the Reverb level is turned up high?
« Last Edit: September 16, 2026, 11:26:28 pm by VintageRob »
« Reply #9 on: September 16, 2026, 11:22:16 pm »
The name ain't Suckley dude!
Offline VintageRob
« Reply #10 on: September 16, 2026, 11:28:30 pm »
Apologies, sorry Sluckey. Fingers typed faster than my brain! Please don't take offense.
« Reply #11 on: September 16, 2026, 11:38:38 pm »
No offense taken. We're cool.  :grin:
« Reply #12 on: September 17, 2026, 11:59:50 pm »
...there is a slight hum when the Volume control is at zero.
Could be
1) 'hummy' preamp tube in stage after Vol pot
2) sub-par signal ground return arrangements (or poor grounding)
3) bad filter cap (or bad bias-supply filter cap)
If you solder a couple of insulated gator/test clips to a 0.1uF or 0.01uF 600V film cap and attach one of the clips to where the signal ground goes to the chassis, then you can (carefully) clip the other end on and off various points in the signal path, (like at each plate) and see if any particular points kill the hum noise more than others. Watch out for high voltages* (What you're doing is shunting each stage to ground to see if the subsequent stages still make hum)
*i.e., don't turn yourself into a current return path between high voltage and ground
« Last Edit: September 18, 2026, 12:04:01 am by tubeswell »
Offline wsscott
« Reply #13 on: September 19, 2026, 04:03:11 pm »
VintageRob-I had the same problem as you in the same location.  My build was a modified ReVibe based on a Magnatone 10A circuit that used its preamp circuit up to the Phase Inverter. So its a different situation than your amp. Mine has a tube driven reverb tank vs. one powered by a transformer. The V1 and the Recovery Driver tubes were both 12AX7.  I was experiencing 120hz hum in the same area as you.  I changed my grounding scheme to a Star Ground, and that helped.  Then I added a Hum Loop Blocker circuit and that helped some more, but I was still getting that hum.  I checked the components in that part of the Recovery circuit and they were up to specs.
So finally I replaced V1 with a 12AY7 and that greatly improved the hum remaining.  I really didn't notice a decrease in gain, but I know there is some since I can now turn the Volume on the Mod Revibe up to 3 o'clock without distortion, where before it was starting at around 10 o'clock.
I was so impressed with that improvement that I decided to replace the 12AX7 for the Recovery circuit with another 12AY7 and that finally did it for me.  It's 98% gone.
I know my situation is different than yours, but you may want to try changing some of the tubes to a lower gain.  I didn't need much gain in my Mod Revibe because the circuit was going to be sending Unity signal back to the main amp where the amplification takes place.
I hope this helps.
