September 08, 2026, 07:12:58 pm
Hoffman Amps Forum image Author Topic: does a bias tool exist like this:  (Read 13138 times)
Offline jasperok
« on: April 11, 2008, 05:39:28 am »
gonna be  building a bias check tool but had an idea so want to see if its worth doing!
Basicaly i havea couple of spare hammonds for effect pedals here and was thinking how cheap these meters were:
http://cgi.ebay.com/3-Digital-Blue-LED-AC-0-700V-Volt-Panel-Meter_W0QQitemZ350045436811QQihZ022QQcategoryZ25411QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/3-Digital-Blue-LED-DC-0-2A-Amp-Panel-Meter_W0QQitemZ350044892061QQihZ022QQcategoryZ25411QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
now what i was thinking was having two female banana connections on the side of the box with a switch to choose which meter is measuring .  then a nother switch to AB the two sockets.?
is there a schematic anywhwere for anything like this - my main concern is that i didnt build anything that could damage myself and perhaps protect the meters some way as well,
might be a silly idea - i'm new to all this so forgive me if i have been a bit niave!
maybe these units already exist and would be cheaper and safer to buy premade?  though i am sure once the theory is right i can build it safe enough.
Offline jasperok
Re: does a bias tool exist like this:
« Reply #1 on: April 11, 2008, 05:52:04 am »
http://www.thomann.de/gb/tube_ampdoctor_biasmaster.htm
ah the bias master
well thats about 200 dollars by the time it is shipped.
mmm
any schematics about for that type of thing - cant be that much to em.
Offline PRNDL
  • Tube or not Tube, that is the question
« Reply #2 on: April 11, 2008, 09:23:20 am »
I thought it would be handy to display the current in all two or four tubes at the same time, which would be nice when trying to match tubes for a Twin or 100 watt Marshall.
The second feature is to have an easy way to change sockets from octal to 9-pin.
As for the circuit, it's fairly simple:
 voltage between the anode and cathode,
 current tap between the cathode male and female pins,
 all other pins are male to female
It is important to spend some thought on designing the sockets to be rugged enough for professional use.
Check out my new tweed Retro 6V6 combo
http://www.naturdoctor.com/Chapters/Amps/RetroV.html
Paper-in-oil caps are cool!
Offline rafe
  • I have tube amps
« Reply #3 on: April 11, 2008, 02:05:43 pm »
Here is a simple version ......make two that should be plenty to match tubes ......Get a couple MA meters or DVM's and you are in ....cheap
    http://www.el34world.com/charts/biascurrent.htm
Rafe
Offline jasperok
« Reply #4 on: April 11, 2008, 03:18:59 pm »
yeag your right -
it would be be silly to get anything more expensive.
the lost digital AM i can find is 0- +_ 2A (the one above)
however it shows to 3 decimal places so i presume it will show 0.035 A as 35ma - is that in the correct range do you think?
the 600v meter should be perfect two.
Offline PRNDL
« Reply #5 on: April 11, 2008, 05:41:39 pm »
A better way would be to get a millivolt meter connected to a high precision 1 ohm resistor between the cathode male and female pins. This 0-20V meter might be suitable
http://cgi.ebay.com/3-Digital-Blue-LED-DC-0-20V-Volt-Panel-Meter_W0QQitemZ230241329272QQihZ013QQcategoryZ25411QQcmdZViewItemQQ_trksidZp1742.m153.l1262QQ_trksidZp1742.m153.l1262
I wonder what would be better (more accurate) - using the millivolt meter and a 1 ohm (1%) resistor, or the ammeter.
It's easier to switch with the millivolt meter, since you don't have to interrupt current flow. On the other hand, the wire length will decrease accuracy.
« Last Edit: April 12, 2008, 12:35:31 am by PRNDL »
