September 08, 2026, 03:49:14 pm
Hoffman Amps Forum image Author Topic: 68 Princeton cap job (AA964)  (Read 6037 times)
Offline Geezer
« on: June 18, 2005, 06:17:15 am »
        >     68 Princeton cap job (AA964)
<< Prev Topic | Next Topic >>
Author  Comment
jayjaylinks
Junior tube assistant
(4/10/04 1:26 am)
 Today I was given an alternative for replacing the cap can in a Princeton. I'm just getting into the amp thing, so I thought a safe place to start is tuning up my recently acquired Princeton. A repair guy told me that the can containing the 3(?) caps would cost about $60, but I could buy 3 separate caps, for much cheaper, and mount them on turrets over the area where the can is. I noticed Hoffman has some cap cans, but not the one I was looking for(I don't think). I'm just wondering what route to go. If I do the route of mounting 3 caps in the chassis, I would need a schematic/layout of how to do it. If the cans can be obtained and for a reasonable price, then I'd rather go that route to keep the amp as stock as possible. Any help is appreciated.
LooseChange
Senior tube assistant
(4/10/04 7:17 am)
 Re: 68 Princeton cap job (AA964)
 I never noticed that before. Hoffman does not have a 3 section cap for Fenders... What to do, what to do (Doug?) ??
I would get the 3 separate caps and put them into the amp.
Dan
Tiny Daddy
I will work on all amps
(4/10/04 8:50 am)
 You can leave the original can in place for appearances and add separate caps underneath. The can grounds can remain connected but cut loose the other wires and resistors. Add a terminal strip for the new parts. 47uF and 22uF /450V caps are available from several places and the smaller radial-lead caps usually fit in better. Order some new resistors too. And fix the AC wiring with a 3-wire grounded cord.
boogielicious
(4/11/04 1:22 pm)
 You can get the exact replacement for your Princeton at Virbroworld.
www.vibroworld.com/parts/....html#cans
Zack makes the cans there and they work great. The only hard part is melting the solder to remove the old can. I used two 100W irons to do this. Single caps will work fine, but I'll get a bit crowded in the chassis.
Doug stocks the cans used in most amps, but the BF Princeton isn't one of them.
Scott
 Topic Commands
Powered By ezboard® Ver. 7.32
