September 08, 2026, 03:50:44 pm
Hoffman Amps Forum image Author Topic: IEC power input hole         &  (Read 28352 times)
Offline Geezer
« on: June 18, 2005, 06:19:52 am »
        > IEC power input hole
<< Prev Topic | Next Topic >>
Author  Comment
Jonas Gemini
Hey get your own solder
(4/13/04 9:23 pm)
Hello,
Does anyone have an easy way to cut or punch the hole to use a IEC power input on their amps?
Here is the part that I am referring to from the Hoffman parts list
Power cord/Fuse holder receptacle for Bedrock chassis 2 and chassis 3. Uses a standard removable/computer end power cord. Holds a 5 X 20 mm fuse.
It would be nice to do this with a punch, but I can't find one. The hole required is not sqaure.
Jonas
HStraub
Senior tube assistant
(4/13/04 11:11 pm)
 IEC
 Jonas,
I use the one listed above it, and I use a rectangular hole. Are you sure you can't use a rectangular hole?
Before I had the metal shop make my chassis, I used a dremel tool with cutoff wheel to cut the holes. It is a pain in the a$$ but it worked.
Jonas Gemini
(4/14/04 7:13 am)
 Re: IEC power input hole
Thanks Harry,
Where can I find one of this rectangular tools? You're right, the old way is a pain.
Jonas
ernie jr
Junior tube assistant
(4/14/04 7:31 am)
 hole cutter
 ocean state electronics
has a tool called a nibbler. it is great to make odd
shaped holes
ernie
ganzonimx
(4/14/04 4:42 pm)
 Re: hole cutter
 at McMasters I saw square hole punches, all well over 200 bugs ...
I stay with my jig saw to cut the receptacel holes out of the chassis..
Cris
 Topic Commands
Powered By ezboard® Ver. 7.32
