September 08, 2026, 06:25:26 pm
Hoffman Amps Forum image Author Topic: Epiphone EA 33RVT amp  (Read 13248 times)
Offline FKitchen
« on: May 14, 2008, 07:43:45 am »
I have an epiphone amp EA 33RVT for over thirty years. When it turns on it hums loudly.After looking inside the one tube looks burnt.Looking at the schematic it appears to be V4 (6AQ5).I do not see any reference to this tube ,maybe it is so old that it changed I do not know all of this is new to me.HELP!!!!!!!PLEASE!!!!!!
Offline FYL
Re: Epiphone EA 33RVT amp
« Reply #1 on: May 14, 2008, 11:21:21 am »
The hum is probably caused by dead filtering caps, something pretty normal after 30 years. Have the amp examined and serviced by a qualified tech - IMO changing a few caps and fitting new tubes will bring her back to her full glory.
Here's a full schemo:
http://www.schematicheaven.com/gibsonamps/ea_33rvt-galaxie.pdf
Offline FKitchen
« Reply #2 on: May 14, 2008, 01:56:48 pm »
DO YOU KNOW WHAT THE CURRENT TYPE OF TUBES ARE THAT ARE USED IN THIS AMP?
Offline FYL
« Reply #3 on: May 14, 2008, 02:23:09 pm »
They are listed on the schemo.
Changing tubes isn't a viable option: the amp should be fuly checked by a qualified technician. And your <CAPS LOCK> key is stuck...
Offline RicharD
    • Toxic Water
« Reply #4 on: May 14, 2008, 02:29:36 pm »
http://www.mif.pg.gda.pl/homepages/frank/vs.html
6AQ5 = EL90 = 6005
Dieing tubes don't hum, they crackle followed by silence.
Cap job.
« Last Edit: May 14, 2008, 02:30:15 pm by Butterylicious »
« Reply #5 on: May 14, 2008, 04:36:15 pm »
6AQ5 = EL90 = 6005
Cap job.
how is it that you know that?  :D
Offline RicharD
    • Toxic Water
« Reply #6 on: May 14, 2008, 05:00:23 pm »
Experience.... recent experience.
What was the final death toll again?
« Reply #7 on: May 14, 2008, 06:44:08 pm »
i lost count...  :(
Offline Iannone
  • If it's too loud, you're too old
« Reply #8 on: May 15, 2008, 04:05:03 pm »
I agree that you should look to the power supply cps first.  However, if you find yourself needing new output tubes, you might look at:
http://www.vacuumtube.com/guitar.htm
While the 6AQ5 is no longer in production, there are still some reasonably priced NOS bottles available.
