September 08, 2026, 11:15:11 pm
Hoffman Amps Forum image Author Topic: Gibson GA-18T, GA-8T & GA-5T  (Read 15974 times)
« on: May 26, 2008, 06:12:22 am »
Somebody needed a layout to scratch build a GA-18T, so I drew this up. The schematic just shows one input jack with 27k value & I added some 470 ohm resistors to the 6V6 screens.
Apparently, there are at least three different GA-18/GA-18T versions. This one is the tweed style with 12AX7's (not 6EU7's), 6V6's (not EL84's) & a 5Y3 rectifier (not 6CA4).
« Last Edit: June 10, 2009, 12:55:46 pm by tubenit »
Re: Gibson GA-18T & GA-8T
« Reply #1 on: June 16, 2008, 05:33:44 am »
 This is the Gibson GA-8T/Epiphone EA-35T amp & Gibsonette amp.
Also the GA -5T.
Check for errors. Compare to original copies on Schematic Heaven
« Last Edit: June 27, 2009, 10:41:15 am by tubenit »
Offline lego4040
Re: Gibson GA-18T, GA-8T & GA-5T
« Reply #2 on: April 19, 2014, 12:59:06 pm »
Tubenit, I Just found this and I was wondering what program I need to open this GA18T layout? My windows does not recognize. I think Id like to do Gibsons GA18T version of Fenders tremolux since I have a extra matched set of EL84's. I know you made this layout for the 12ax7 and 6v6's but if I just changed the pins back to the EL's and 6Eu7 would that work?
Offline lego4040
« Reply #3 on: April 19, 2014, 01:34:23 pm »
I found the link here to open sch. the expresspcb program. I can view layout now but I still would like to know what needs to be one to use the El84's?
« Reply #4 on: April 19, 2014, 04:14:26 pm »
The GA-18T is a 6BQ5 amp. Just lookup the original schematic in Doug's schematic library.
Offline lego4040
« Reply #5 on: April 19, 2014, 05:18:35 pm »
I printed out both the 16T and 18T for reference and wrote down pins for both the 6v6/12ax7 version and the el84/6? Version. I read they are same circuit but I already see different values on input resistors
