September 19, 2026, 02:18:22 am
Hoffman Amps Forum image Author Topic: Need Push/Pull switch for mod  (Read 14367 times)
Offline NannerPuddin
« on: June 01, 2008, 10:35:36 am »
I am doing some mods on a Boss SD-1 pedal, and I want to activate with a push pull switch on the Level pot, which is a 10k mini pot.  I can't find the 10k with a push pull switch.  Does anyone know where I can find them?  I already found a 1m to use for the drive knob, but I need one for the Level.
Doug
Offline LooseChange
    • Fix Your Darn Amps
Re: Need Push/Pull switch for mod
« Reply #1 on: June 02, 2008, 06:12:07 am »
http://www.mouser.com/catalog/634/675.pdf
Style "d" or "c"
But tell me, where did you find the elusive 1M???
Call me Dan
www.fydamps.com
« Reply #2 on: June 02, 2008, 07:58:57 am »
LooseChange,
Thanks!  I have been going crazy trying to find that!!  BTW, I found the 1m here...
http://www.smallbearelec.com/Detail.bok?no=619
Thanks again!
Doug
« Reply #3 on: June 05, 2008, 07:59:11 am »
Well I realized that the push/pull pots listed on that page are linear taper only and I think I need the audio taper for the level pot.  Ii talked to the tech guy at Mouser and they don't have one like that.
Back to the drawing board I guess.....
Doug
Tyler
  • Guest
« Reply #4 on: June 28, 2009, 02:36:40 pm »
Here's a few ways to give a linear pot an audio taper.  It's supposed to be more accurate than manufactured audio pots and a hell of a lot easier than taking a pot apart and scraping at the conductor.
http://www.geofex.com/article_folders/potsecrets/potscret.htm
Happy One Year Anniversary of posting this question   :laugh:
Offline GuitarPilot65
  • Music by Lee/Lifeson; Lyrics by Peart
« Reply #5 on: June 28, 2009, 05:25:59 pm »
I picked-up a 1MΩ from here
http://www.torresengineering.com/ampsolshafpu.html
The taper turned out to be pittifully flat to approximately 7 on the vol. dial.  Ended up putting stock pit back in.
1993 Brown Fender '63 Vibroverb RI (6G16)
1994 Blonde Fender '65 Deluxe Reverb RI (AB763, modified [by me])
