September 17, 2026, 06:27:27 am
Hoffman Amps Forum image Author Topic: plexi bias            (Read 35867 times)
Offline Geezer
plexi bias
« on: June 18, 2005, 06:36:25 am »
        > plexi bias
<< Prev Topic | Next Topic >>
Author  Comment
jerrydyer
Junior tube assistant
(4/22/04 11:56 pm)
 plexi bias
 watt is the correct bias for a 50 watt and a 100 watt both els4's thanx also can you bias it while on or should I just stick to standby?
Tiny Daddy
I will work on all amps
(4/23/04 8:05 am)
 Re: plexi bias
 Bias current depends on the tube's plate voltage. Install 1-ohm resistors on the cathodes for measuring purposes, then adjust the current for 70% plate dissipation (17.5 or 18 Watts for EL34). This cannot be done in standby. For example if the plate voltage is 500V then 18 divided by 500 = 36mA per tube. Measure the plate voltage at the plate before and after adjusting and you may have to re-adjust.
jerrydyer
(4/23/04 10:08 am)
 bias
 is it safe to touch pin 5 with a meter while amp is on ? thanx
Tiny Daddy
(4/23/04 10:31 am)
 Re: bias
 Pin 5 being the control grid: If you have a good high-impedance meter with fet or tube input, you may read the bias voltage. If it's a low-impedance VOM it may load the bias to a lower level, give an inaccurate reading and maybe cause the tube to over-dissipate if left connected.
Be sure the speaker is connected any time a tube amp is on.
 Topic Commands
Powered By ezboard® Ver. 7.32
