July 29, 2026, 01:31:18 am
Hoffman Amps Forum image Author Topic: Soldering gun or iron?  (Read 8888 times)
Offline GuitarPilot65
  • Music by Lee/Lifeson; Lyrics by Peart
« on: June 18, 2008, 01:13:23 pm »
I have a Weller soldering gun which I use for all of my soldering work around the house, including recent mods to my DRRI:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=372-030
I replaced the tip with a "heavier-duty" Weller model, since tips specific to my model were unavailable at the store where I went.  Some recent work on small gauge headphone extension cables appears to have "cold' solder joints (e.g., wire coming loose from plug lugs after some jostling).
Is this a factor of too much heat due to the different tips?
Should I invest in a constant-temp iron for my upcoming amp kit project rather than use my gun, or will it be ok to use if I get the proper replacement tips?
Thanks for reading.
1993 Brown Fender '63 Vibroverb RI (6G16)
1994 Blonde Fender '65 Deluxe Reverb RI (AB763, modified [by me])
Offline Fresh_Start
  • noob de Lux
Re: Soldering gun or iron?
« Reply #1 on: June 18, 2008, 02:02:27 pm »
Please look at the sticky at the top of this forum for answers to many questions, including soldering info.
Short answer:  75 watts is way too much for amp work.  Weller makes a nice 5-40 watt station:  http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=372-120
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #2 on: June 18, 2008, 02:44:59 pm »
I beg your pardon; could you please be more specific as to how to navigate to the soldering info you cite above?
Thanks for the recommendation and link to an alternate soldering device.   :)
Offline Fresh_Start
  • noob de Lux
« Reply #3 on: June 20, 2008, 12:13:53 am »
Here's the sticky:  http://www.el34world.com/Forum/yabb2/YaBB.pl?num=1206454819 The soldering info is in the second post toward the bottom.
HTH
Chip
Quote from: PRR
« Reply #4 on: June 20, 2008, 01:33:56 pm »
Ah, it's at the top of "Tube Amp Building - Tweaks - Repairs" topic, not this Amp Tools topic.
Thanks again.
