September 17, 2026, 03:20:10 am
Hoffman Amps Forum image Author Topic: TuInside Tube amps        (Read 27829 times)
Offline Geezer
TuInside Tube amps
« on: June 18, 2005, 06:38:02 am »
        > TuInside Tube amps
<< Prev Topic | Next Topic >>
Author  Comment
Leevi
Junior tube assistant
(4/23/04 12:32 am)
 TuInside Tube amps
 I'm reading Dan Torres's book Inside Tube Amps.
He writes and presents a table regarding amplification in his book that the gain can be increased in an amplifier stage by increasing the value of the plate and/or cathode resistor.
Maybe I have misunderstood, but according to my understanding the gain decreases if I increase the value of the cathode resistor. Which one is correct?
Leevi
Woolly
(4/23/04 4:52 am)
 Re: TuInside Tube amps
 increasing cathode decreases gain.,,,that book is full of hype and bad information,,throw it out,, Kevin O'conner's TUT's are much better..
zachsdad
(4/23/04 5:03 am)
 Stage Gain
 The formula for gain is:
(plate resistance) // (plate load) // (following grid resistance)
(1/transconductance) + (cathode resistance)
where // means "in parallel with"
By increasing the numerator, such as plate load, the gain increases.
By increasing the denominator, such as cathode resistor, the gain decreases.
Leslie
tubejunky
(4/23/04 5:28 am)
 I'm also in the process of reading Inside Tube Amps, and was confused by that as well. There is some interesting info in the book though, $34 from AES.
Leevi
(4/23/04 11:38 am)
 Re: Inside Tube amps
 Thank you for your answers guys. I have not bought the book, it´s from library. Which one of the Kevin O´Connor´s Ultimate tone book do you recommend? I´m looking for a book that contains good basic information related to tube amplifiers and tube technology. Dan Torres´ book is written for musicians and the way he presents the things is not always so scientific.
/Leevi
Funkalicousgroove
(4/23/04 12:25 pm)
 The best book out there for this (if you can find a copy) is the 2nd edition of The audio cyclopedia by howard tremaine, it is thorough, easy to understand, and in a question and answer format. WWW.Aikenamps.com is also a wonderful resource for all things musical and tube, he has a listing of reccommended reading as well as some wonderful tech info-check it out-
jc
I only work on Fender's
(4/23/04 4:07 pm)
 The first TUT book is a good general starting place. The first 2 TUT books are about 1/2 tube and 1/2 solid state. The first book has a lot on channel switching. The 2nd has a lot on solid state amplifiers. The 3rd TUT book is an amplifier projects. He goes through designs for AC-30, plexi, bassman, etc. He tries to use common transformers (hammond). They all have a lot of good information. The first TUT is probably the best starting place.
The aiken site is a great resource along with the web in general.
Leevi
(4/24/04 11:53 pm)
 thanks jc, below is some more information regarding Kevin O´Connors´books.
/Leevi
www.londonpower.com/books.htm
 Topic Commands
Powered By ezboard® Ver. 7.32
