September 08, 2026, 02:54:17 pm
Hoffman Amps Forum image Author Topic: firing up my revibe. What do I need to k   &n  (Read 42358 times)
Offline Geezer
« on: June 18, 2005, 06:47:50 am »
        > firing up my revibe. What do I need to know?
<< Prev Topic | Next Topic >>
Author  Comment
johnt1
Junior tube assistant
(4/13/04 12:41 pm)
 I have one item left to hook up on my revibe unit. The heater wires. I anticipate having that portion completed this evening. I have a few question's before putting power to the unit. Capacitors ? Can I just give them full power. Base on prior post I believe thats OK. Secondly ? voltage readings. Should I follow the Hoffman kit instructions for initial fire up. Would I expect to find the same voltages as this is not a amp. I believe they would still hold true but I want to make sure.
Il let you know how I make out.
John T.
bluetonene
(4/13/04 1:29 pm)
  Re: firing up my revibe. What do I need to know?
 When ever I fire up a new build I do so using a current limiter,ie: a 100watt light bulb in series with the power with the unit. This way if there is something shorted the bulb will stay glowimg brightly and you won't fry anything. I'm just curious as to other builders, I always start a project by wiring the heaters first but have yet to build the Re-Vibe. I think it may be eaiser this way, any thoughts?
Tom
Wanabejimi
(4/13/04 2:54 pm)
 Yea, if you don't have a variac...I'd consider using the current limiter. I have also read the other posts about firing up with full power. I'd imgagine that would be OK if everything is wired OK, but mistakes are easy to make.
...and I wire my heaters first. They are such a pain that I find it easier to do without all the other wiring in the way.
Please post the results of your revibe! I've got all the parts on my bench and will probably begin my build this weekend.
Funkalicousgroove
(4/13/04 4:38 pm)
 I always fire mine right up, but I also check every single solder point for continuity before I plug it in, Leo Fender never used a variac and I GUARANTEE he didn't have pre-formed caps. I always do my heaters Last, I don't know why-It's just how I was taught. I do have a good method though: I Take about 6 ft of wire, bend it in half right down the middle, put a pen or something to give me a nice handle and then I pre-twist my wire and cut it to the right lengths(This only works if you put your heater wires in the air).
bnwitt
Senior tube assistant
(4/13/04 4:45 pm)
 Funk,
we are twin sons of different mothers. I fire my amps up full on too. I always start out with only the rectifier tube if there is one and no tubes if not. Voltage checks follow, and if all is well, I pop in the other tubes and go. Of course I make sure all wiring is correct, and since I have now built in excess of 100 amps, my mistakes are few and far between. In the beginning, however, I made some real doozies so I gained the habit of the start up mentioned above. I am also a proponent of floating heater wires and use the same twisting method as you. On my high end amps I use an expensive Cross pen instead of a pencil though. Just kidding.
wshubert
(4/13/04 4:56 pm)
 I have always put full power to it. and never had any problems
with the caps. I wire my heaters up last ,because I route them
from above and go straight down to each socket.Never had any hum problems this way. alot of this is personal preference
and old habits.
jc
I only work on Fender's
(4/13/04 6:32 pm)
 I power up similiar to Barry. Tube rectifier only, check voltages. Then the rest of the tubes. I normally have my guitar plugged in and on the stand. Take it off of standby and strum the guitar. No noise, turn it off quick!
Lots of good advice about checking your wiring. I like to check that all of my ground points have continuity to ground .
I use to run the heaters in the air but found that I would occasionally hit one with the soldering iron if I was messing around in the amp at a later date. That kind of stuff drives me crazy because I can't just tape it up I would have to rewire that heater section.
I decided to go with wiring the heaters first and shoving them against the back of chassis so that they would be out of the way.
johnt1
(4/15/04 7:46 am)
  revibe no revibe
 OK good news bad news. I went ahead and just fired up the unit. Nothing blew. The voltages seem right. Bad news, I have no reverb or vibrato. I can hear the reverb when I tap on the reverb tank. It seems as though there is no signal. The two items I am not 100% sure of are the input plug with 1 meg resister. I have continuity on every tab to ground on the input jack. I dont think thats right. The other item is the stereo jack for the foot switch. I have one empty tab left. Is that sound right.
Thanks John T.
johnt1
(4/15/04 8:18 am)
  no revibe
 Ok , something is not right on the input jack. I just dont know what. When I open up the jack tip from the inside contact I still have continuity. I have one side of the 1 meg resister on pos terminal along with the two sh wire hook ups. The shield to ground. The other side of the 1 meg resister on the remaining two lugs then to ground. Is this correct. Thanks John T.
johnt1
(4/15/04 10:56 am)
  revibe
 Ok good news to report I rewired the input plug. The unit works. I now have few minor problems to address. The foot switch for the vibrato side is not working although the reverb side is. The speed pot seems to be backwards. Need help with that. There seems to be to much hum. I did lift the ground leg with a plug addapter. There is no difference with or with out the lift. If any one can help me throuhg these last items I would be greatfull.
Thanks John T.
Wanabejimi
(4/16/04 10:14 am)
  Re: revibe
 As far as the speed pot is concerned...I think all you need to do is to reverse what is on the outer lugs of the pot and you should be good to go.
The hum could be coming from a lot of places. Are the jacks insulated from the chassis? Do the heaters have access to ground with two 100 ohm resistors? Try pulling some of the preamp tubes and see if the hum goes away or stays with each tube....that might narrow the search for the hum down a bit.
Let us know how that bad boy sounds once you get it dialed in!!
johnt1
(4/16/04 12:40 pm)
  revibe
 WBJ, thanks for the reply. Yes I did use the 100 ohm resisters on the heaters. I also have tried two sets of tubes with no change. The jacks are not isolated from the chassis. I used the hoffman style set up. They are tied to the ground bus along the back of the pots. AS I did not read this was required I am assuming the hum is from another source. Perhaps some other revibe builders can shed some light on this. The reverb sounds really good. The vibrato has a sort of thump sound when cranked to 10. Iam not sure it should. My 66 princton and drri run very smooth all the way up. I am hoping the pot conection is a factor. The hum is not super loud. But I feel the unit should run a little quieter. I also plan on changing the sh cables on the input jack I wired the jack incorrectly the first time. Now after rewiring the jack almost touches the cable when inserted. Thanks for the help WBJ.
John T.
johnt1
(4/17/04 12:44 pm)
  revibe works, but needs fine tune!
 OK, I have reversed the wires on the speed pot. It seems to have worked. I still have few kinks. First I think the hum issue is related to the vibrato section. The reverb seems OK, sounds good. The vibrato is not smooth when cranked. I also think the intensity should be a little fuller. I have something wrong. The vibrato is there weather or not the switch is on or off. On the reverb side you have to activate the switch. I used a 1/4" stereo plug for the foot switch. I ran the vibrato line to the tip lug. the reverb to the side lug. Can some one help me through this stereo plug hook up.
Thanks John T.
bnwitt
(4/17/04 8:50 pm)
  Re: revibe works, but needs fine tune!
 John,
it's pretty simple
Tip = Reverb
Ring= Tremolo
Sleeve=ground
or ....
Tip = Tremolo
Ring= Reverb
Sleeve=ground
whatever you wire the foot switch to be, you need to make sure th
Offline Geezer
Re: firing up my revibe. #2
« Reply #1 on: June 23, 2005, 07:41:43 am »
Re: revibe works, but needs fine tune!  John,
it's pretty simple
Tip = Reverb
Ring= Tremolo
Sleeve=ground
or ....
Tip = Tremolo
Ring= Reverb
Sleeve=ground
whatever you wire the foot switch to be, you need to make sure the jack is wired the same. Don't forget that 220Kohm resistor on the reverb return/footswitch assembly.
johnt1
(4/17/04 11:18 pm)
      revibe unit Barry thanks for the reply. I believe thats what I have. I ran a white wire from V1 pin 2 to the center lug of the reverb return.then I ran the 220 k resister from the same lug to the ground of the 1/4" stereo jack. I ran a jumper from the reverb return center lug to the barrel lug of the reverb rerurn. I ran the vibrato foot switch wire from the 1 meg .01 lug over to the tip lug of the stereo jack. There is still one tab left that is in contact with the inside of the tip . should i have something on this contact.
Thanks John T.
EL34
I got your parts right here.
(4/20/04 3:56 pm)
      Re: revibe unit Firing them up cold turkey works the best usually.
It's good to have a meter connected and be monitoring current levels in power tubes the first time.
Set the bias to the extreme cold side and bring the bias up slowly on fixed bias amps. Just monitor the power tube current in cathode biased amps.
Double check everything twice beforehand. If you are the sloppy type that skips steps intending on doing them later, this may not be the best method for you.
I used to gloat everytime I fired up a new amp and only heard the low hiss from the speaker. Set the bias, monitor the bias for a while and re-set it after a burn in period.
Have your hand on the power switch in case something seems wrong. Do not hessitate to shut the amp off immediately if even the smallest thing seems weird.
johnt1
(4/20/04 6:59 pm)
      revibe unit Doug thanks for the reply. The unit seems basically OK. I have no idea what kind of voltages I should be looking for in the revibe unit. I believe I had about 315 v on pins 3 & 4 of the power tube. The reverb sounds good. My problem now is the vibrato. I know my pedal is good. but it has no effect on the unit. The vibrato is just on. The vibrato also seems to have a thumping sound when turned up all the way. I also am not sure how quiet the unit should be. I believe I need to make a few minor tweaks. Any advice is welcome Thanks.
John T.
EL34
(4/21/04 9:18 am)
      Re: revibe unit It's different for every amp, there is no standard.
You can just measure what you have and see if it is all working properly.
You can look at any fender layout diagram and see the voltages for your every day normal tube stages.
A 12ax7 with a 1.5 cathode resistor works the same and has approx the same cathode voltages in many amps. 1 to 2 volts.
johnt1
(4/21/04 11:34 pm)
      help with my revibe ! My reverb on my revibe unit sounds great. I found the problem with the vibrato foot switch. I have one last problem. both the intensity and the speed work, but with the intensity up all the way,when the speed is past 5 the unit seems to motor boat you can hear a thumping sound. I also wonder if the vibrato should sound a little fuller. The vibrato on my revibe is not quite as pronounced as my 66 princeton. I don't know what the 5g13 should sound like.
Need advice.
Thanks john t.
johnt1
(4/23/04 10:55 am)
      revibe I am not getting a consistent reading on v5 pin 6. I think the resister at 4.7 meg may be bad. Would this cause the vibrato to motor boat.
Thanks John T.
EL34
(4/23/04 12:07 pm)
      Re: revibe You won't get any meaningfull readings on a tremolo/vibrato occillator tube stage.
Forget about trying to figure out what voltages are supposed to be on a trem stage.
bnwitt
(4/23/04 1:05 pm)
      Re: revibe John,
do you have the mp3 file of the Weber sponsored revibe? If not, I could email it to you so you can hear what it sounds like.
Doug,
could you do a sound file of the Hoffman Reverb/Tremolo unit?
johnt1
(4/24/04 12:50 am)
      Re: firing up my revibe. What do I need to know? Barry thanks much,No I don't have that file. That might be a big help. I cant tell if my revibe is correct or not. The reverb is great. The vibrato section however, has a helicopter sound in the background when the intensity and speed are pushed past 6 or so at the same time. Dose that sound right to you. If not I would think is is something minor I have missed. I can give you my Email let me know.
Thanks John T.
bnwitt
(4/24/04 2:15 am)
      Re: firing up my revibe. What do I need to know? John,
email me at bnwitt@hotmail.com and I will send you the file.
johnt1
(4/26/04 3:40 pm)
      revibe unit Barry. thanks for the info. A few other observations I have made on my revibe. Lifting the ground makes no difference in the hum. Actually the unit seems a bit quieter using the ground. I also noticed the hum is there even when I turn the volume down all the way on my guitar. I tried a fender reverb with my 5e3 clone. Still had some hum but not as loud as my revibe. I did notice when using the 63 reverb that when I turned the volume on the guitar down. There was no sound at all at the amp. I also think my revibe reverb had better reverb. You have made a few revibe how much hum should I have? Should lifting the ground make a noticeable difference?
John T.
bnwitt
(4/26/04 6:38 pm)
      Re: revibe unit John,
My Verbolos (what I call them) have had pretty low level hum, but definitely more than one of my amps. All of the hoffman style amps are very quiet, but the revibe is a little noisier. Lifting the ground should reduce the hum only if the hum is being caused by a ground loop between the two devices(amp and revibe). If this does not impact your noise level then it may be coming from some other problem. Here is some info from Randall Aiken's website regarding hum:
Q: How can I find out if the hum in my amp is caused by the filament wiring?
A: Disconnect the 6.3V AC wires from the power transformer, and temporarily connect in a 6V lantern battery. If the hum is caused by filament wiring, or by induction from the filament inside the tube, it will go away with the battery connected. If the hum is caused by something else, such as a ground loop, it will not go away when the filaments are run on DC.
Q: How can I get rid of the hum if it is caused by the filaments?
A: The best way to get rid of the hum is to generate a DC filament supply, but this isn't always practical, because of the high dissipation caused by the large current draw of the filaments. First, make sure the filament wires are run as twisted pairs, then make sure they aren't routed too close to sensitive grid wires or next to coupling capacitors. If that doesn't do it, try "elevating" the center tap of the filament winding (or junction of the two filament reference resistors) to a potential above the cathode voltage of the tubes, typically between 10V - 50V or so. You can generate this voltage with a couple of resistors arranged as a voltage divider from the plate supply. Be sure to bypass the junction of the resistors to ground with a suitable filter capacitor, or you may inject some buzz or noise into the amplifier from the power supply.
Q: What if the hum is not caused by the filaments?
A: If the amp still hums when a battery is substituted for the filament supply, the cause is most likely one of four things: either the AC wiring (plate supply, filament supply, or mains input) is running too close to a sensitive stage, the transformers themselves are inducing hum into sensitive stages, there is too much residual ripple on the main power or bias supplies, or there is ground loop hum caused by a poor grounding scheme in the amplifier. The true cause has to be determined by a process of elimination. Sometimes it is advantageous to pull preamp tubes, one by one, starting at the input, to determine if the hum is getting in to a particular stage."
I have built all of my units with a cap board and cap can for the filter caps and not placed them inside the chassis. I do that because the chassis is so darn tight and I don't know really if that reduces the overall noise or not. I am also using three separate chassis grounds in the unit. One for the green power cord wire, one for the preamp ground (buss wire on back of pots)like Doug shows and one for the filter caps. I think the only way to compare is for me to record my recent revibe in different settings to an MP3 file for your listening pleasure. I can also use a sound pressure meter to compare a hoffman 5E3's hum by itself to the amp with a Revibe unit in line. Give me a couple of days to do that and I'll post it on my website this weekend.
Barry
Edited by: bnwitt at: 4/26/04 6:40 pm
