September 15, 2026, 10:13:46 pm
Hoffman Amps Forum image Author Topic: removing chassis rivets          (Read 32102 times)
Offline Geezer
« on: June 23, 2005, 05:14:24 am »
        > removing chassis rivets
<< Prev Topic | Next Topic >>
Author  Comment
Van
Junior tube assistant
(5/26/05 1:34 pm)
Reply  removing chassis rivets
 Does anyone know of an easy way to remove chassis rivets ? I've got an old Silvertone chassis that I'd like to build something else in, but the sockets are riveted.
Funkalicousgroove
I only work on tube amps
(5/26/05 1:43 pm)
Reply  Re: removing chassis rivets
 Drill through them then crush them with vice grips and push them through-maybe?
Or grind one end off with a dremel
PhatTele
(5/26/05 1:59 pm)
 I drill through them. They usually split apart and are fairly easy to remove. Wear saftey goggles!!...they can blow apart too.
Tiny Daddy
I only work on Fender's
(5/26/05 3:15 pm)
 If they are ordinary brass rivits I drill them. Usually the rivit starts spinning and won't drill so I use a cordless drill and drill at about 30 degree angle to keep it cutting. Also I am using a 3/16 bit, or 1/8 for smaller rivits so it just drills off the rivit head.
Pop rivits are a different kind of problem and I use a small pin punch, made from a jewlers screwdriver, to knock out the remains of the steel pin before drilling.
ampcabinets
Senior tube assistant
(5/26/05 5:08 pm)
Reply
 I usually use an oversized drill if I can get to them from the inside, drill off just the roll-over and then tap them out.
Van
(5/26/05 5:27 pm)
Reply  RIVETS
 On behalf of my o'possum, and myself, I thank you all for your replies.
gehicks
(5/26/05 10:37 pm)
Reply  Re: RIVETS
 Damn, I thought I was the only one here with a pet possum!
Van
(5/27/05 2:12 pm)
Reply  Possum rivets
 Isn't it comforting to know you're not alone in this cold, cold, cruel world ? Yes... amps and O'possums are an unbeatable combination.
 Topic Commands
Powered By ezboard® Ver. 7.32
