September 08, 2026, 02:53:24 pm
Hoffman Amps Forum image Author Topic: Is there any danger in using a 6L6 tube when    (Read 39218 times)
Offline Geezer
« on: June 23, 2005, 05:19:42 am »
        > Is there any danger in using a 6L6 tube when the plastic...
<< Prev Topic | Next Topic >>
Author  Comment
jmaulz
Junior tube assistant
(5/23/05 8:42 pm)
Reply  Is there any danger in using a 6L6 tube when the plastic...
 ...cylindrical piece in the middle of the pins that lines up the tube to the socket is broken off?
Thanks, Mike.
LooseChange
I only work on Fender's
(5/23/05 9:07 pm)
Reply  Re: Is there any danger in using a 6L6 tube when the plastic
 Nothing wrong with that. I use em' all the time. Just be VERY careful how you install it. It needs to go in the right way. You can usually see where the pin was.
Tiny Daddy
(5/23/05 10:36 pm)
 AES sells slip-on replacement pins. Kind of pricey though if you only need one.
6G6
I only work on tube amps
(5/24/05 4:55 am)
 If you don't have it out much, you could just mark the base, next to pin one with the tip of a knife and line that up with a pencil mark on the chassis, next to it's socket.
The tube dosen't care at all if it has the line up pin, but it sure
picky about having the pins lined up with the socket correctly.
eddiejg
(5/24/05 11:04 am)
 I always crazy glue them back on.
I break them off all the time.
-Ed
 Topic Commands
Powered By ezboard® Ver. 7.32
