September 08, 2026, 11:26:53 am
Hoffman Amps Forum image Author Topic: Studio 15 (4001 with mods)  (Read 14044 times)
« on: September 18, 2008, 10:16:26 am »
I changed numerous things from the Studio 15:
This one uses a GZ34 instead of solid state.
It has a dpdt center off on V1a for cathode caps being paralleled
It has a negative feedback switch
It has the attentuation cathode bypass switch
It has just cathode bias and not cathode plus fixed bias both
It does not use DC on the heaters
I have NOT built this. Check for errors and compare to original Studio 15/ Marshall 4001
with respect, Tubenit
« Last Edit: April 07, 2012, 07:11:58 am by tubenit »
Re: Studio 15 (4001 with mods)
« Reply #1 on: September 18, 2008, 01:16:22 pm »
I have NOT built this.  I have only glanced over it to CHECK for ERRORS.  If you see any, please leave a post and I'll work to get it corrected.
Any discrepency between layout and schematic .................. refer to the schematic as "correct".
« Last Edit: April 07, 2012, 07:36:55 am by tubenit »
dbtk44
  • Guest
« Reply #2 on: October 12, 2008, 05:05:54 pm »
Just curious, has anybody built or worked with this one? I'd like to take a crack at it, but since it seems to be preliminary I wonder if the schematic and layout are both workable?
Oh, And thank you for sharing this Tubenit!
Offline equinox
« Reply #3 on: March 24, 2012, 10:07:55 am »
Ditto! It seems like someone did some work and the Studio 15 w/ 6V6 was a great base.  I'd like to know how this turned up and hear some clips if possible.  Please let us know.  Thanks in advance.
Equinox
