September 08, 2026, 03:49:15 pm
Hoffman Amps Forum image Author Topic: another heater question    (Read 12922 times)
Offline Geezer
« on: June 17, 2005, 08:28:28 pm »
        > another heater question
<< Prev Topic | Next Topic >>
Author  Comment
sfsorrow01
Junior tube assistant
(2/2/04 2:37 pm)
 was just re biasing my hoffman 5f6a and thought i'd check the heater v, and it seems i'm only getting 6.3 off one wire, w/o valves in and measuring from the lamp connection. Shouldn't it be 3.15 from both? is my tranny buggered? All replies much appreciated.
Rotting27
(2/2/04 8:02 pm)
 Re:
 It depends on what method you used to wire your heaters. The modern standard of 4+5 - 9 wired independently, with a centertap to ground, should measure 6.3VAC across the two wires, but 3.15 from one wire to ground.
sfsorrow01
(2/3/04 6:28 am)
 Re:
hi rotting, thanks for the reply. I am using the standard heater setup, ala doug but i'm getting 0v on one side and 6.3v on the other. is there anything i can do? or is it time for a new tranny?
sfsorrow01
(2/3/04 1:02 pm)
 update
 after a lot of cursing i stripped the heater wire on the tranny which had no voltage only to find it had broken under the insulation. all is now well.
Rotting27
(2/4/04 3:31 am)
 Re: update
 rock!
 Topic Commands
Powered By ezboard® Ver. 7.32
