September 08, 2026, 11:26:14 am
Hoffman Amps Forum image Author Topic: Bassman 5F6-A, & Bassman w/Reverb  (Read 42715 times)
« on: November 13, 2006, 05:15:46 pm »
Original schematic for the Bassman 5F6-A      The original Marshall BluesBreaker is pretty similar. Check Schematic Heaven for comparisons.  Note on the BluesBreaker layout, I split the V1 cathodes for more tone options.
Check for errors
Tubenit
*  I've added one confirmed to be a great sounding working model for a Bassman with reverb and tremolo by Tubeswell.
« Last Edit: September 01, 2018, 02:58:11 pm by tubenit »
Bassman with reverb
« Reply #1 on: November 13, 2006, 06:03:58 pm »
I've used this type of D'Lite reverb successfully in numerous builds including the Little Wing Reverb (mini-Bassman), Texas Raptor and Plexi 25w Reverb.  Compare schematic and layout and CHECK for ERRORS.
Tubenit
EDIT:   I added another idea using a mosfet CF so one could have an extra triode allowing a 12AT7 reverb send.  Also to note:   2 input jacks instead of four,   split cathodes on V1,   mosfet CF and one extra stage of filtering.
CHECK for ERRORS!  Compare schematic with layout, if there is a discrepancy, go with the information on the schematic.
« Last Edit: August 28, 2018, 06:51:03 am by tubenit »
1 Channel Quasi-M schm
« Reply #2 on: May 01, 2007, 08:54:35 am »
One of the forum posters PM's me and asked if I had a simple schematic for a one channel Marshall.  So I drew this up.  It does have a paralleled V1 which only give 30% more gain but adds some warmth in my opinion. I have this feature on all of my amps and love it.
You can use a 5751 or 12AY7 if you wanted lower gain.  OR .... you could simply hook up only half of the V1 12AX7.
I haven't built this, but one could use terminal strips or a Hiwatt style board and probably make a small sized 50 watt head.
Note with the SPDT (center off) on V1 that you can come pretty close to the original values for both Marshall channels.  I indicated some questions about some resistor values on the B+ and bias control.  I put what my best guess is. If you build it, maybe you'll let us know if these are accurate?
« Last Edit: June 10, 2009, 02:46:21 pm by tubenit »
Bassman and AB763 channel switching with relays
« Reply #3 on: December 15, 2012, 08:25:28 am »
Some different ideas to consider here.....................
 :think1: :icon_biggrin:
Adjusting the two channels to be the same or similar volume could be done by:
1)  using the hotswitch boost
2)  lower the Bassman mixing resistor to a lower value (maybe 68k) or
     even eliminate it
3)  add a 250k pot where the V5-7 grid resistor is on the DR channel
Just other options to consider .................
With respect, 10thtx
« Last Edit: February 03, 2013, 06:39:11 am by tubenit »
