August 04, 2026, 04:58:46 pm
Hoffman Amps Forum image Author Topic: interesting OP-AMPs  (Read 22133 times)
interesting OP-AMPs
« on: January 29, 2009, 03:21:56 pm »
Offline JayB
Re: interesting OP-AMPs
« Reply #1 on: January 31, 2009, 08:10:24 am »
Have you done anything with this ISO? Looks like it's just as simple to use as a normal opamp. I was thinking about doing a rg100es type of amp. I got the transformers that I raped out of an old pioneer stereo amp. This opamp would make it simple for a stereo output amp.
You're going to hell faster than Britney Spears running to a Barber shop
« Reply #2 on: February 02, 2009, 06:26:24 am »
i have not... they are expensive. i was thinking more along the lines as application for a PS regulator for the screens of a higher powered bass amp using 6550s or 6146s.
if i were to build an audio amp around an op-amp - i'd use this device.  :)
Offline JayB
« Reply #3 on: February 02, 2009, 04:37:39 pm »
That looks like some thing I can work with and I got tons of aluminum to make heat sinks with. Might just be able to use eyelets with it if I can space those legs out right.
http://pdf1.alldatasheet.com/datasheet-pdf/view/218576/NSC/LME49830.html
