September 08, 2026, 11:22:18 am
Hoffman Amps Forum image Author Topic: Bright cap across vol pot?  (Read 21401 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
« on: January 31, 2009, 09:01:00 pm »
My SG's pickups are unbalanced- 498t/490r- and it's not an output thing.  The bass on the neck pickup is so prominent, it causes a huge jump in peceived volume when I am playing clean- it's not playing nice with the bridge.  Before replacing it, I wondered if I could put a bright cap accross the volume pot?  I just need to tone the bass frequencies down a bit.  If this doesn't work, then I'll be looking for a brighter neck pickup (and i have no idea where to start- SD Jazz?).
Thanks!
FDeSalvo,
Principal Engineer & Owner,
Re: Bright cap across vol pot?
« Reply #1 on: January 31, 2009, 10:46:58 pm »
Lowering the bass string side of the bass heavy pickup should do the trick.
Have you considered String guage; string height; pickup height; pole pice hieght?  If you do go with new pickups, I have recently fallen in love with Lindy Fralin Unbuckers.
Offline G._Hoffman
« Reply #2 on: February 02, 2009, 12:31:39 am »
They are awfully nice, aren't they.  I'm increasingly fond of his pickups.  And I started out pretty fond of them to begin with!
You might also try going to a brighter string - say something with a stainless steel wrap.
Gabriel
Offline fdesalvo
  • "...I can walk!!"
« Reply #3 on: February 03, 2009, 10:15:05 pm »
Yeah, lowering the pickup isn't working- it bottoms out quickly in the SG's thin body and the screws start backing out.  I'm going to get a strat for the single coil tones, but I definitely need a brighter bucker!
FDeSalvo,
Offline G._Hoffman
« Reply #4 on: February 04, 2009, 12:42:05 am »
Try Lindy Fralin's P-92's or Unbuckers.My guess is you will like them.
But if you are after making it brighter, a high pass cap will likely help.  Along with keeping the guitar brighter as you turn down, they also make the guitar brighter overall (which is why I don't usually like them, but then I'm not after the same thing as you).
Gabriel
Offline bluesbear
« Reply #5 on: February 04, 2009, 07:14:10 am »
Sounds to me like you just need an HB with less windings. That ought to cure both your problems. It would be less bass heavy and have a lower output. Call Seymour Duncan and ask what they have with a lower output. Tell them exactly what your problem is. They're good people to deal with and, let's face it, they make so many different pickups, they're bound to have something for you.
Tel: (805) 964-9610
Dave
Offline G._Hoffman
« Reply #6 on: February 04, 2009, 03:46:38 pm »
Tel: (805) 964-9610
Dave
The Alnico II Pro, the `59, and the Pearly Gates would all fit that bill.  An Unbucker would probably be better.
Gabriel
Offline fdesalvo
  • "...I can walk!!"
« Reply #7 on: February 04, 2009, 11:27:03 pm »
Guys-- my search has led me to the SH-2/Jazz!  I will update when I have a chance to play through it.
FDeSalvo,
Offline fdesalvo
  • "...I can walk!!"
« Reply #8 on: February 12, 2009, 02:53:15 pm »
SD Jazz wins!!! Amazing!  Sounds great split, too!  I can run my distortion through the neck pickup- finally.
FDeSalvo,
Offline G._Hoffman
« Reply #9 on: February 12, 2009, 03:11:20 pm »
I've always been fond of the Jazz distorted for some things.  It has a level of articulation that other pickups just don't have, and there are times when actually being able to understand the notes you are playing is a very good thing.
Gabriel
