September 08, 2026, 11:23:59 am
Hoffman Amps Forum image Author Topic: For maximum string balance. How do You adjust your pick ups  (Read 15907 times)
Terry
  • Guest
 and screw heights.....Do you look for maximum string balance or how do you look at it?  Then what do you do to get it?
Offline G._Hoffman
Re: For maximum string balance. How do You adjust your pick ups
« Reply #1 on: March 02, 2009, 06:22:22 pm »
I do it by ear.  I start with the neck pickup, getting the E strings to balance.  Most of the time I put the neck pickup to where it is about 1/16"-1/8" from the strings when they are fretted at the last fret.  Balance the outside E strings, and then adjust the rest of the pole pieces to match.  Then I adjust the other pickups to match - I usually make the bridge pickup a bit hotter.  I check balance with single notes, and with strummed chords.
It works for me, and my customers seem to like it well enough (or at least, I don't get any complaints!)
Gabriel
Terry
  • Guest
« Reply #2 on: March 06, 2009, 07:04:01 pm »
Thanks Gab.  That refines my method.
Offline G._Hoffman
« Reply #3 on: March 07, 2009, 03:27:08 am »
I should also mention, on my personal Strat I have the pickups quite a bit farther away from the strings.  It gives that bell like thing - experiment on the overall distance to find what you like.  It's not a one size fits all thing.
Gabriel
Terry
  • Guest
« Reply #4 on: March 09, 2009, 04:20:02 pm »
I tried the above now and quite a nice little improvement.  Thanks!
Offline G._Hoffman
« Reply #5 on: March 09, 2009, 11:50:47 pm »
You read so much about people using measurements to do this, and you just have to ask, "why?"  Your ear will always be the best tool.
Gabriel
