July 25, 2026, 10:51:34 am
Hoffman Amps Forum image Author Topic: How does one make an Auralex Gramma?  (Read 14052 times)
Terry
  • Guest
« on: March 14, 2009, 11:06:09 am »
It really looks like it's worth looking into.  All it is is A thick piece of MDF  board ... what is that!!?? (I'll bet thats comercio babble for chipboard), a piece of carpet and two dense foam rails.  It is susposed to isolate your tube amp & speaker cab.  Joe Bonamassa has something like that and loves it.  C'mon doesn't it sound like a great idea.
How would you go about it.  And where would you find the materials.  If they sell for $59, I'm going to assume $5 in materials.
I always have my amps on 2 by 4's nailed together to make a little lift off the floor, but this sounds even better.
« Last Edit: March 14, 2009, 11:10:53 am by Terry »
Offline bluesbear
Re: How does one make an Auralex Gramma?
« Reply #1 on: March 14, 2009, 12:15:20 pm »
MDF = medium density fiberboard
You could get everything you'd need at Lowes, Home Depot, etc.
Dave
Offline Geezer
« Reply #2 on: March 14, 2009, 12:21:19 pm »
Offline tubesornothing
« Reply #3 on: March 14, 2009, 01:03:10 pm »
How about a nice set of isolation foam pads for the feet of the amp?
Terry
  • Guest
« Reply #4 on: March 14, 2009, 01:43:34 pm »
Do you mean the amp head that goes on top of the cabinet?
Offline Frankenamp
  • What does this button do?
« Reply #5 on: March 14, 2009, 02:44:39 pm »
You can do it with a half inch sheet of MDF or solid (no voids) plywood. carpet isn't critical, you can paint it yer favorite colour. the trick is in the strips of foam: If I was making one I'd steal a few tricks out of Beranake or another acoustics text and use at least a couple of different consistancies of foam med/soft/firm to damp a broad range of frequencies. (remember the weight on a spring theoretical stuff?) the foam is the spring here, and you want something that absorbs and does not resonate.
This problem calls for a bigger hammer!
Offline Dynaflow
  • Have a cow man!
« Reply #6 on: March 14, 2009, 02:57:51 pm »
 Perhaps some of those wrists supports for computer keyboards glued on the bottom? The rubber palm rest pads. I have a 5e3 head thats getting its tubes shaken like crazy that I just built (has 6l6's and through a 2x12 bottom its got some bass)... :D May have to make something like that to isolate the head a bit...
Regards,
Dyna
Offline Frankenamp
« Reply #7 on: March 14, 2009, 06:20:05 pm »
computer wrist pads? good idea! that and some liquid nails* and yer set!
Offline drew
« Reply #8 on: March 14, 2009, 09:31:05 pm »
If you're going to use MDF, get it cut to size at the store.  Sawing that stuff creates a dust storm like you can't believe.
Terry
  • Guest
« Reply #9 on: March 22, 2009, 07:03:08 am »
FINISHED!   So far they work great!  I got foam rails from a guy who saved the exact thing from large shipping crates (they protected voting machines). I got free indoor/outdoor carpet samples.  I used russian birch plywood instead of the MDF...big deal, it cost me $15. to do "4" auralex grammas. They told me that was the densest stuff they had. I had to buy a whole sheet if I got the MDF.  Plus $4. for some plastic tub installation glue in a caulk format.
I'm serious, I tried them at church today as well.  It's like getting everything you worked for to get the amp sounding great back from the "room" your in.
« Last Edit: March 22, 2009, 12:04:46 pm by Terry »
